Question about Maytag LAT2300 Top Load Washer
Maytag washer model LAT9316AAE won't agitate or spin
Hi! My Maytag washer model number LAT9316AAE fills up with water and then makes a humming sound like it is running but it barely moves, if at all. So apparently it doesn't agitate or spin. It does drain though, although it left the clothes very wet since it was not spinning. I have not had a chance to check on the belts or anything since I have to move it out of a closet to do this. I was hoping to have some things to look for before I move it out. Any help would be greatly appreciated, it's not easy dragging 3 kids to the laundry mat. :) Thanks!
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: washer won't spin or agitate
On this model the motor turns one way for spin and the other for agitation. This action is controlled by a thrust bearing located just undernieth the plastic cap on the center pully. Many people are thrown off thinking a transmission problem when it's actually this thrust bearing kit. However, it could be the trans. If so you have a 5 year warranty on it, part only. There is also a number of service flashes on this model including: snubber kit, flash number 26-756, which has to do with vibration during spin. Things you want to make sure of is that the pump is not seized up, leakage from the center tub on to the bearing and brake. You may want to call Maytag and inquire about the service flashes on this model, you could be covered. Other than that my guess without seeing it would be the thrust bearing kit, part number 12500036. Not a bad job, the kit comes with instructions. The hardest part is getting that last washer on. Catriver...Post back.
Posted on Aug 06, 2006
natengel
  • 19 Answers
SOURCE: Agitator
change agitator dogs
Posted on Oct 31, 2007
  • 96 Answers
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Washer wont spin or agitate
sounds like you got current, but it won't engage.....the belt could have come off
Apr 22, 2012 | Maytag Washing Machines
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Fills with Water but, that is it
If a machine spins and drains, but won't agitate, that sounds like a timer control problem. Wires can come loose or burn up, but that's not as common as a failed contact. If the machine won't agitate or spin, that could be a lid switch problem, which is real easy to fix.
Mar 25, 2009 | Maytag LAT3600A Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
326 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
