Question about LG 26LX1D 26 in. LCD HDTV
Tv guide/tuner problems
I lost the tv guide function and I I cannot keep some channels on the DTV side. I am not on cable, just OTA HDTV antenna. I get the major stations, but PBS and some other indie chnls will go away. I would reset the channel search, and they will come back briefly. Mostly, the tv guide function is dead. Everything else is fine.
HELP!!
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Posted on Apr 22, 2008
Is the TV Tuner in the 8806 analog only? It cant be used for OTA DTV?
GPX KCL8806DT television receiver has only an analog broadcast tuner to receive digital from Time Warner you will require a converter box.
Feb 17, 2015 | GPX KCL8806DT 7 in. Portable Television
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
Help I cannot get any tv channels on mo lg 32 combo
What is your TV source? If you are looking for OTA (over the air) signals, you may need to modify your antenna setup. An external antenna rotated to the correct direction usually works best. See antennaweb.org and tvfool.com for details of what stations you may receive OTA. Antennaweb is much more conservative in the channel availability list than TVfool is. On both sites, enter your street adress for the details.
If you had a recent surge through your antenna, then you may have to repair/replace the TV tuner. (My household lost three CRT TVafter a nearby lightning strike.)
(Antennaweb.org lists only my area as only getting 2 channels with an external antenna (one transmitter source - 10 miles away). We actually get more - the other channels are transmitted from ~30 miles away.)
Jan 01, 2010 | LG 32LG40 32 in. LCD HDTV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Sudden no signal on digital channels on a Vizio VX37L
Your cable signals are probably encoded so that you have to use their cable box for reception. Renders your tv tuner useless used for OTA.
Aug 28, 2017 | Vizio VX37L Television
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Digital television signals
What type of digital tv signal? Satellite or OTA (Local Digital Antenna Channels)?
What type of equipment is the split signal going to? Straight to the tv's or some sort of Satellite or HDTV Tuner box?
Dec 19, 2007 | Motorola HDT101 DTV Receiver
LG 26LX1D 26 in. LCD HDTV Logo
429 people viewed this question
