Home | Palm | Tungsten E2 (Multilingual) Handheld | My Palm Tungsten E wil...
Palm Tungsten E2  Handheld
Problem for Palm Tungsten E2 (Multilingual) Handheld
My Palm Tungsten E will niot hot synch with my new
By devault1 on Oct 10, 2009
My Palm Tungsten E will niot hot synch with my new computer which is an HP Pavilion dv2-1030us Notebook which is operated by Vista. I've been able to load the program but it won't hot synch. The battery, which is old & might need to be replaced will charge being attached to a USB port.
Comments:
Oct 10, 2009
- My Tungsten E (it does not indicate E2)will not Hot Synch with my new computer which is operated by Vista. The program will load on the computer but no data can be stored. I get a message on my Palm stating "The connection between your handheld computer and the desktop could not be established. Please check your setup and try again." I have tried downloading from my disk,& the internet. I've spent money with an I T tech, I've been told (this past summer)that Palm does not have a patch for Vista. My cable is good, even bought a new one & can't Hot Synch. I'm not real computer saavy & might do better with a phone call. I have created a shortcut, loaded the Palm program, unloaded the program, re-installed the program. HELP
Oct 10, 2009
- Hi,
Below is a better description of the problem. Should I uninstall the Palm software from my computer before going to the link you suggested? I saw some comments about doing a hard re-set of the Palm, but I can't afford to lose the data. Changing the name on the Palm won't work because a program I subscribe to on the internet won't recognize me.
Oct 10, 2009
- Have uninstalled Palm soft ware. Should I also uninstall:
Power2Go & PowerDirector ?
The icons for the shortcut to Palm still remain
Oct 10, 2009
- Have downloaded/installed Palm 6.2 it wants a new usernamewill I not be abled to receive updates from the internet program I subscribe to? Is there anyway I can keep my old username & still hot synch stuff already on my palm? I think not.Please answer ASAP because tI can't continue
Oct 10, 2009
- It made me change my name on the download. How do I change my name on the Palm device? Can I speak with you by phone? PLEASE, I'm not real good at this. I'll shut off computer & Palm, restart both & try to Hot Synch again, I receive the same message as before that "The connection between my handheld computer and the desktop could not be established. Please try your setup and try again." The computer shows a cable with a button, my cable does not have a button.
Solution #1
posted on Oct 10, 2009
Somewhat Helpful)
97F350diesel
Rank: Guru
Rating: 86%, 200 votes
When you plug it in does it recognize the device?? Also you need to make sure you download the most recent software and that it is compatible with Vista..
Solution #2
Not Rated)
Ekse
Rank: Guru
Rating: 88%, 4674 votes
You need to download the latest vista version of the program, the one on the disc is unlikely to work.
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
Get it from the above linked page.
You may have to restart the computer and press the reset button on your device, it should hotsync after the computer has started and you see the hotsync icon in your taskbar. bottom right corner area of your screen.
if the issue remains please follow the step by step advice on this page
http://kb.palm.com/wps/portal/kb/common/article/2630_en.html
Comments:
Oct 10, 2009
- Yes, remove the old version.
Oct 10, 2009
- Also, the software I've linked to you supports the following
Windows versions
  • Windows Vista Basic, Home Premium, Business and Ultimate
    Please note: 64-bit Windows Vista is not supported for USB synchronization. However, 64-bit Windows users may be able to sync through a Bluetooth wireless connection. After installing Palm Desktop 6.2, see: Synchronizing under 64-bit Windows Vista: Bluetooth HotSync setup.
  • Windows XP Home and Professional (32-bit editions)
  • Windows Media Center Edition 2005
Oct 10, 2009
- Uninstall all palm related software for now. A icon on the desktop does not matter much. Then just install the required version and follow instructions, it should work.
Oct 10, 2009
- you will have to enter a new username then, you may want to hard reset your phone aswell and start from fresh, that will avoid many problems.
Oct 10, 2009
- No we don't provide phone support at this time.
If noting else helps, do a hard reset and setup a completely new name on the device. it will ask on the hotsync to add a new name.
Popular Solutions for Palm Tungsten E2 Handheld
Questions and Unsolved Problems for Palm Tungsten E2 Handheld
Do you recommend Palm Tungsten E2 (Multilingual) Handheld?
Answer
Answer
i can't access my list of pdf files. I need to delete some files but the application jumps from the... (More)
Answer
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the... (More)
Answer
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back.... (More)
Answer
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Palm Tungsten E2 Handheld:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
