Question about Nintendo NES Console
NES in Black and white only...?!
My wife got me an original NES for Xmas - the only problem is that it outputs video only in black and white. This happens for all games, with the RF connector or with RCA jacks, multiple cords were tried, fiddled with, etc. I can't get ANY color to appear at any time. Tried with multiple TVs, too. It's definitely the NES. It's a refurbished system with a new 72-pin connector.
Can anyone pin this problem down and offer a solution?
  • Anonymous Apr 16, 2009
    I have the same problem. I have a new 72 pin connector (becouse I thought that was the problem) and my nes only outputs black and white. The games work fine, i tried multiple cables and a few tv's... Does anyone know what the problem could be (a solution would be even better)?
I had the same problem but switching to an different TV fixed my problem.
Posted on Dec 05, 2009
  • sandy357 Dec 05, 2009
    This is from the Manual....
    Symptom - Game playfield is on screen, but picture is fuzzy, has no color or
    has snow in it.
    - Make sure that the antenna is connected to the RF switch properly and that
    the RF switch is connected to the TV. (Refer to "Connecting the NES Control
    Deck to your TV set".)
    - Adjust the fine-tune and contrast controls on your TV to receive the
    clearest picture possible.
    - If your TV has an automatic fine-tuning control (AFC), turn it off and use
    the manual fine-tuning control to get a better picture. (If your TV loses
    its color when the AFC is off, turn it back on.)
    - If the Control Deck is too close to the television, the Control Deck may
    cause some interference. Try moving the Control Deck farther from the TV.
    - If there is interference on Channel 3, change the Channel 3/Channel 4 switch
    on your control deck to Channel 4 and set your TV to Channel 4.
    - A particularly strong television station may be broadcasting on Channel 3
    or 4 (or on cable TV) in your area and causing interference. Try disconnect-
    ing the antenna wire from the RF switch. (You will have to reconnect it
    again for regular television viewing.)
My system has done that a couple times. Not sure what the problem was, but changing the channel in back to "4" and restarting the system would show the game in color (turn TV to 4), then switching everything back to channel "3" everything was fine again. This has worked on several occasions, again not sure why.
Posted on May 17, 2009
    Problem Solver:
  • 5 Answers
Thats quite a odd issue, and I have never heard or seen a case such as this. Maybe your color balance chip is fried? NES is a 20+ year old system, so I wouldn't doubt the NES may have more issues then just a lockout chip error or a new pin connector.
Posted on Jan 04, 2008
NES help
This is possible a problem with your A/V cords. Try "jiggling" them around when you have the NES turned on, and if there is no picture or sound after that, you may need a new set of the cables.
Jun 19, 2013 | Nintendo NES Console
My Super Nintendo is showing up with black and white colors. It plays fine there is just no color, only black and white. Is it fixable?
Depending on the age or your television, this could be a simple fix. Newer TVs seem to be unable to translate the simple video colors from the Super Nintendo and thus render them in black and white. Try using an older TV.
Oct 28, 2010 | Nintendo Super NES Console
On the original nes when you put in the game it works and everything but there isnt any color its black and white
Well I think that it might be your tv or the rf switch is causing the problem then not the consoles.
Sep 06, 2010 | Nintendo NES Console
SNES plays in black and white
If you have tried all the standard tricks (checking tv, inputs correct, clean cartridges, etc) you may need to open up your super NES. once the top is off you'll see a motherboard protected by an aluminum cover plate. At the bottom left of the cover plate (just behind controller #1 input and immediately to the right of the power switch) you'll see a hole in the plate with an adjustable trim pot below on the motherboard. This may have become dusty over time like the volume controls on an old transistor radio. Use a jewellery screwdriver to move it back and forth a few times then return it to its original position (I adjusted mine with the power on and connected to the TV for optimum picture). This fixed the problem.
Dec 28, 2009 | Nintendo Super NES Console
Games are in black and white-no color
Make sure the cables are hooked up properly. Audio to the audio input and video into the video input of the tv.
If they are hooked up right and you still only get black and white pictures then the cable might be bad so get a new cable.
If you still have a problem even with a new cable then its something to do with the connector in the SNES or the main board itself.
May 21, 2009 | Nintendo Super NES Console
Nintendo nes only plays in black and white
there might be a problem with your tv
Dec 21, 2008 | Nintendo NES Console
Nes flashing black and white and making a horrible sound
a 'front load' nes ALWAYS does this, even if the connector pins inside the console are new. the cartriges on a Front Load nes rarely completely seat, as Nintendo redesigned the Famicom very poorly for the US market. try this 1. put the cart in as usual, but hold it all the way down 2. slip an unwanted/extra cart in on top of the metal hoop above the cart your using. this gives a better contact for the cart. try cleaning the cartrige pins as well. some won't read right if there's ANYTHING on the pins.
Dec 03, 2008 | Nintendo NES Console
Nintendo NES Console Logo
1,403 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
