Question about Kenmore Oasis HE 27082 Top Load Washer
No display lock with load inside - Kenmore Oasis HE 27082 Top Load Washer
  • 2 more comments
  • Anonymous Dec 29, 2007
    i also have the kenmore top loading oasis.. and just as i was washing a load (small) the machine starts beeping like crazy. go to look and it turned off.. no clue whats going on, but i did notice that the lid lock is not activating so its turning off.. now the machine is not turning on at all. nothing is blocking the locking mechanism and i never had this problem before. sears will not even give me an idea what it could be because i do not have a warranty. i hope someone can help me out here..
    my kenmore elite oasis HE washer is not locking shut. and sears will not help me out since i do not have a warranty.. (never buy from them) now my machine will not even turn on.. help me someone..
  • eppiemg Jul 04, 2008
    It's so true, but let me tell you that having a warranty doesn't even help. I have a 3 year and had the machine for 2. It just went dead with clothes in it and water and the service dept was disgustingly rude and nasty and told me I have to wait until July 17th for a service call because they have no idea whatsoever on how to unlock the lid of this machine to get the clothes out. If I pry open the lid, I will void the warranty so I can't do that. They won't even give me the number to the service dept in my area so I can call myself. I am not buying anything from Sears again!
  • Madmom101 Oct 15, 2008
    My Oasis just died. Nothing happens when I try to power it on. Now I have to wait till Sears repair man shows up (for over 7 days!) and tries to fix this problem. I will never buy from Sears again!
I own and operate an appliance repair company , in my opinion the oasis is one of the poorest designed washers available and sears is not standing behind their product. i repair all brands and models of equipment and have to say the whirlpool duet is a good machine for the money.
Posted on Jan 31, 2008
How do I fix my washer with an F-22 code
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed. The following link explains how to troubleshoot and repair:
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
There is a tech sheet located inside the washer behind the lower kick panel under the door. Refer to your tech sheet for more detailed information concerned connector plug numbering and troubleshooting of the CCU.
If you still have questions, please let me know. I hope this helps you.
Jul 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Maytag MAH21pddww door locked
hi thanks for the question to unlock the dor manually open the soap door look to the right top inside its a small piece of string pull on it. that should unlock the door thanks the appliance doc
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi zwf14581w front load washer
Are there clothes locked inside machine or water visible inside machine? Either machine has not drained eg.blocked drain hose or pump, or door lock broke .please reply.
Jun 02, 2008 | Zanussi Washing Machines
Disk stuck inside player, LOCK shows on display
Try pushing and holding the power button until lock is cleared. I have a different model daewoo dvrs04 but that's how it works for my dvd. Hope it helps
Mar 16, 2008 | Televison & Video
No display on Kenmore Oasis
there should be a repair manual inside the machine. If you use a screw driver in the front to open the top of the machine the manual should be on the inside of the front panel.
Oct 13, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
53 people viewed this question
Sal De
 Brian Main
Brian Main
