Question about Jensen VM9510 Car DVD Player
In dash How can i change the light on my in dash from blue to red?
  • 1,586 Answers
I don't think you can - it's likely that it's an LCD-type screen illumination, not bulbs that can be changed. I haven't yet heard of anyone able to do this. I wish it was possible though - I have the 9311TS in my Audi, and the Audi uses red dash illumination.
Posted on Oct 08, 2008
Have a 1994 Dodge Ram 1500 4x4 1500 with wiring problems. The original problem was a brake light out on the drivers side. I changed the tail light plugs. With head lights off I had brake lights with head...
Your truck may have had the factory trailer tow package, but that did not come with a wiring connector in that year. There should be a wire harness under the rear of the truck near the center of the bumper with 7 wires of the following colors/characteristics -
Red/Orange - +12V Battery (Thick Wire) From fuse #8 (40A)
Black/Orange - Tail Markers (Thick Wire)
Light Blue - Trailer Brakes (Thick Wire)
Violet/Black - Backup Lights (Thin Wire)
Dark Green/Red - Left Stop/Turn - (Thin Wire)
Brown/Red - Right Stop/Turn - (Thin Wire)
Black - Ground - (Thick Wire)
Under the dash, the brake controller wiring should be -
Black/Orange - Ground - (Thick Wire)
White/Tan - Brake Light sense - (Thin Wire)
Hope this helps.
Mar 19, 2013 | 1994 Dodge Ram
Need to know color code of speaker wires for 1995 dodge ram van
Here you go i hope this helps.....this is for the full size van.
Constant 12V+ Pink Switched 12V+ Red/White Ground Chassis Illumination Black/Yellow Dimmer n/a Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Blue/Red Rear Speakers 6" x 9" Side Panels Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Blue/White Right Rear (-) Blue/Orange
Mar 17, 2011 | Dodge Ram 3500 Cars & Trucks
I need speaker wire color codes from in dash the colors i have are blue and white gray black tan green and black brown and green white and pink blue and pinik
This should be what you need
Constant 12v+ Wire: Green/Violet
Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green
Illumination Wire: Light Blue/Red
Antenna Trigger: Orange/Blue
Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Dec 26, 2010 | 1995 Ford Explorer
Radio wiring diagram for 2000 dodge grand caravan
2000 Dodge Caravan Stereo Wiring Constant 12V+ Pink Switched 12V+ Red/White Ground Ground/Back Strap Illumination Black/Yellow Dimmer n/a Antenna Right Front Front Speakers 5 1/4" Dash Left Front (+) Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Blue/Red Rear Speakers 6" x 9" Side Panels Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Blue/Orange Right Rear (-) Blue/White
Dec 22, 2010 | Car Audio & Video
How do i connect a telephone wire to an rj11 plug. What is the order of the wires for us telephones.
dialtone should go on the green and red wires of the jack for 1 line service, yellow and black for a second line.
Depending on the type of wiring that your dealing with the color code can change. if your wiring has white wires with little dashes of color on them then the code is:
green = white/blue (mostly white with blue dashes)
red = blue/white (mostly blue with white dashes)
black= white/orange (mostly white with orange dashes)
yellow= orange/white (mostly orange with white dashes)
Oct 23, 2009 | Lands Phones
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
I need to know the speaker wires from the dash to the speakers on a 1995 dodge b250 van
Jun 09, 2009 | 1995 Dodge B Series Cargo
Replace burnt light in instrument panel 1999 toyota corolla
I've changed my dash lights out for Red and later Blue for a nice change. I had to pull the cluster (i.e. speedometer unit) out of the dash. You have to remove an trim pannel on the face of the dash to expose the screws holding the cluster in. Once you have them exposed you will then remove the screws and pull the cluster forward to get to the lights pluged into the back. If you want to change the color then this is the time to do it. You can find different colors at your local auto parts stores and some places such as Walmart.
Good luck, I hope this helped you out.
Apr 07, 2009 | 1999 Toyota Corolla
Putting in a alpine deck into my cirrus
Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground Ground/Back Strap Illumination Orange/Brown Dimmer Black/Light Blue Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Light Green/Green Left Front (-) Light Green/Purple Right Front (+) Light Blue/Green Right Front (-) Light Blue/Purple Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Blue/Light Blue Right Rear (+) Dark Blue/White Right Rear (-)
Dark Blue/Orange
Mar 28, 2009 | Alpine CDA-9847 CD Player
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Jensen VM9510 Car DVD Player Logo
67 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
