Question about Radio Shack Pro-2018 Scanner
I am also new to radio scanning
My brother & I bought my mother a scanner for Christmas. I read the manual, programmed the four stations that she wants, and have it set to scan. I watch the scanning as it occurs in the display screen. The problem is that when it picks up a signal, it is impossible to understand.
The manual only says one little bit about what to do with "squelch". I don't know what the word "squelch" even means. I have it not set so that it's not hissing (all the way counter-clockwise), but not quite halfway toward "maximum", either. When a voice comes on we run to the scanner to attempt to adjust the volume and/or the squelch, but can't seem to get anything that is intelligible.
Please help with how to adjust the audio ... and please explain what "squelch" means. Thank you!
  • laepelba Jan 24, 2008
    Thank you ... I thought this post was forgotten. We are located in a suburban area. My mother had an old scanner (with a whopping four channels) that worked great in the same location. She wanted a new one, so we got it for her. She has a list of the locally used frequencies that I programmed into the new scanner (same exact frequencies she had in the old one). I then checked a couple of different websites that have online lists of frequencies used by the kinds of services that she wants to listen to (local police and fire, etc.) The websites had the same channels that she gave me from her old (ancient) list as well as others that I also programmed in.
    Thank you for your explanation of squelch.
  • laepelba Jan 25, 2008
    Thanks for your help. :-)
  • 204 Answers
Hi, you do not mention where you are located, but my first guess is that you are trying to listen to some freq's that are not compatable with your scanner. The squelch you use to quiet the white noise, so when someone keys their mic the squelch opens easy and allows you to hear them. The scanner you have is a standard FM analog style scanner. Nowdays there is also digital and encripted, trunktracking, and more. None of the different styles are compatable. On my scanners at home I run an external antenna to pull in a greater range. Our local area still runs the standard FM radios. If you respond back with some info, I might be able to narrow the problem down further.
Thank you,,, Mechanic
Posted on Jan 24, 2008
  • Mechanic688
    Mechanic688 Jan 25, 2008
    Maybe it's just me, but I think the older units used to work better. I now use a 100 ch. and to get the same range, I had to add an external antenna. It allows me to hear the car to car activity that does not go thru the repeater. Puts my range at about 25-30 miles. If I'd go up higher on the tower, the range would go up also,,, good luck with it,,, Mechanic
How do I set up a uniden BCT15X
you may have to do a manual scan..or find out what frequency the different companies and police ,fire and airplanes use,,then you may need an outdoor scanner antenna,,the small antenna that comes with the scanner only picks up very strong signals,,,to program the scanner you may have to search online for programming info,,,,good luck
trevor 320
Mar 07, 2015 | Uniden BCT15X Beartracker Scanner
Will not scan properly
Hello
I suppose you are trying to scan the channels by hand, If I'm not mistaken this model can also be hooked up to the pc.
Manual pages 55 and forward are on scanning, I suppose you have been throught those.
I't must be a simple setting wrong somewhere.
May 15, 2008 | Radio Shack Pro-2052 Scanner
How do I program trunking on a BCT8
Read the manual, go through each step after you find out what trunking system they use in your area. Without knowing the trunking type you are lost. Radio reference.com can help you find out.
Jan 26, 2012 | Uniden BCT8 Base Scanner
Radio shack iscan trunking scanner, pro-107
I no longer provide support for any scanners. As a Police Dispatcher I was working when two police officers were ambushed and killed because a person listening to a scanner told the suspects the police were coming. They should be outlawed.
Dec 19, 2011 | Radio Shack Radio Communications
I have a pro-106 and arc software i have tried everyway i know to program a p-25 system in the radio and all i get is garble. the system is gwinnett fire dept in georgia. the police is encrypted but the...
ok Gary tri this go to manual on your pro106 and hit program and hit new and coniventional and then try putting in your p-25 frequency....yes i have this scanner it is awarked to program...Or you can go to tune on your scanner..and scan it that way that is the best way to scan your scanner.....if you have any problems Gary you can email me at randymarr570@msn.com
Jul 08, 2011 | Radio Communications
I bought my friend the iscan pr0-107 truking scanner for Christmas but she is unable to get it to work. No channels are being picked up. Are there areas where the scanner won't work? (we live near...
If you haven't yet programmed it for your area, you won't get much - if any - reception. Most Radio Shack stores will program the scanner for you, or at least give you some valuable assistance in programming it. They can also sell you programming software to simplify the task. IMHO the Butel software available from ScannerMaster.com is the best on the market, and it will let you download virtually every frequency and system in your area directly to the scanner. I also suggest that you visit www.RadioReference.com for a comprehensive database of active freqs and systems in your area, and a lot of other useful scanning information.
Bill B.
Listening in since the 60's
Dec 31, 2010 | Radio Shack Radio Communications
It will scan but not hold a station
Hi
i think the fm settings is not lock in to fm scanner! or program the fm station then lock it in ti memory
Thanks!
Jun 05, 2009 | Coby CX-61 FM Radio
Unit (Pro 95) will not scan trunk tracker stations at all. I have programmed this radio many times previously and it seems that the programming ROMs are misbehaving. The radio works fine in all modes...
go to page 23 of the manual (at "http://support.radioshack.com/manuals/ome20-525.pdf" if you don't have it) it has some cures that you can try there. good luck!
Feb 02, 2009 | Radio Shack Pro-95 Handheld Scanner
New to Radio Scanners
If it just seems to be "stuck" on static, you probably need to adjust the Squelch. Try turning the squelch down until the static stops.
If you haven't programmed any frequencies into the banks, scanning won't do anything. Press "Func" and "Scan" to perform a Search. This way, if you find a frequency with a lot of chatter, you can program it into a bank for scanning later.
The easiest thing to do is to find frequencies for your local police, fire, etc. on the internet & program them into the various banks on the scanner.
BC72XLT user manual (page with PDF link)
Google for local frequencies
Dec 06, 2007 | Uniden BC92XLT Handheld Scanner
Realistic pro-54 scanning reciver
this unit requires crystals for each freq.
Oct 21, 2007 | Radio Communications
Radio Shack Pro-2018 Scanner Logo
101 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
