Home | PC Chips | M810DLU (M810DLUV75C) Motherboard | While playing game , gam...
PC Chips M810DLU  Motherboard
Problem for PC Chips M810DLU (M810DLUV75C) Motherboard
While playing game , game is jumpy , to jumpy to
By 688i on Oct 10, 2009
while playing game , game is jumpy , to jumpy to even shoot someone , how do I fix this ?
Solution #1
posted on Oct 10, 2009
Not Rated)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1919 votes
Your motherboard is quit old. Built in 2003. In order to stop your games from jumping there isn’t just one setting to adjust. It's a combination of settings & hardware currently in your system.
Your graphics driver is built into the motherboard. This built in graphics driver uses your system memory to run your games & display. Most games suggest you run the refresh rate of 60MHz. To set this open windows control panel. Than open the Display icon. Once in Display Properties window click the Settings Tab, than click the Advanced tab. Next click on the Monitor tab.
Under monitor settings change the screen refresh rate to 60 hertz. Click Apply & than OK. Your motherboard will allow you to increase the memory size used for your display/gamming. Unfortunately you can only assign a maximum of 64MB of memory to your graphics/display.
To adjust to this setting you will need to enter the bios menu. To enter your bios, just as your system starts, press the Delete key every 2 seconds. The bios main menu will load.
If you still have your manual, open it to page 24. See, “Share Memory Size”. If you no longer have your manual you can download it from PC chips, left click to open the link; http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=19&detailid=232&DetailName=MANUAL&DetailDesc=M810DLU(V7.5c)&MenuID=39&LanID=2
You’ll find all the drivers for your motherboard on page 3 of this link;
http://www.pcchips.com.tw/PCCWebSite/SearchResult.aspx?q=M810DLU&f=Downloads&MenuID=104&LanID=2
Download & install, Directx 9.0 or 9.0c from Microsoft. Left click on Microsoft’s link below;
http://www.microsoft.com/downloads/details.aspx?FamilyID=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
Even with all the adjustments above you may not see enough improvement for your current gaming. Your last option would be to buy & install a PCI graphics card that uses its own video memory instead of your system memory. If you choose to do this, you will need to chance your bios settings again. See PCI / Plug and Play Setup Page 27 in manual. Any one of the video cards listed at this next link will run with your motherboard;
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Cheers!
Mike
Was this helpful?
Yes
No
Solution #2
Not Rated)
obwhon
Rating: 86%, 157 votes
It's hard to answer this without knowing what game you're playing but if I get the information off the net right your computer is incapable of running any of the new games. It's slow, not much ram and poor video capabilities. A lot of the new games require 2 gigs of ram, a 750 meg video card and at least 2.4 megahertz of power to run excellent. What I see of that motherboard you posted under it's only capable of 1.2 megahertz and probably very little ram and an ancient PCI style video card which is about 8 years back in technology.
Was this helpful?
Yes
No
Popular Solutions for PC Chips M810DLU Motherboard
Questions and Unsolved Problems for PC Chips M810DLU Motherboard
Do you recommend PC Chips M810DLU (M810DLUV75C) Motherboard?
Answer
Answer
why did my computer give me white screen (Laptop)
Answer
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo... (More)
Answer
Hello i have the same problem with pctv110i, do you can solve this problem ?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Chips M810DLU Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14715
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
