Question about Kenmore 43142 Front Load Washer
Kenmore he2 washer will not go into the spin mode. will wash and will tumble the cloths but wont spin them.
  • BillBrad Jan 07, 2008
    I have a Kenmore model 41743142200 front load that won't spin. It stopped working and I found that the belt had fallen off, after replacing it, now I find that washer does everything but spin. During the spin cycle it acts as if it's in wash cycle (it spins several times in one direction then stops and repeats in the other direction until cycle ends).
  • lansult May 11, 2010
    Where is the spin switch, that's not a very technical response.
The spin switch is broken. replace.
Posted on Jan 04, 2008
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Tumble action washer will not spin to remove water from cloths, however it does tumble the cloths during wash cycle, just does not have the high spinning required to remove excess water
This could be a simple fix or the expensive one. Let's try the simple fix first. All dryers have a safety feature for when the washer spins ( mostly for kids to not stick hand in or open lid up when washer is spinning at high speed, to prevent injury) On the lid it self (underneath) has a peg or button that when closes goes into a slot or hole on top of the washer, otherwise known as a switch. Sometimes that switch goes out which has to work for the washer to spin, or has to be bypassed. If you don't know much about bypassing or wiring I would buy a new washer lid switch. There probably under 20 bucks, and easy to replace. Now the expens
May 07, 2011 | Kenmore Washing Machines
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Frigidaire front load washing machine gtlf490e
just change the door switch been there done that have the t shirt
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front loader washer
you need to replace the speed control unit (board) in the lower right corner in the back of the washer it is faulty
Jan 24, 2008 | Kenmore 44102 Front Load Washer
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
