Question about LG 52SX4D 52" HDTV
Turns ON than right back OFF!
The tv cycles and turns on but within 5 sec. it turns right back off into standby mode with the lamp indicator flashing red.
I bought an LG 52SX4D 52 in. I bought it as a floor model at Good Guys when it was closing so I lucked out of a warranty. It's been 3 years and the lamp just went out. I received the new lamp a couple of weeks ago, installed it, worked fine till the next morning when it started acting up. The tv would not turn on 50% of the time which would lead to the lamp indicator flashing red. I had the ballast replaced about a month ago before the lamp went out so I am unsure of what the problem is since the bulb and ballast are pretty much new. Also when the new lamp came in the cords seemed to be switched, flipped in a sense compared to the old lamp, but I was told that it would be fine as long as the lamp is the correct model. So the tv turns on, which makes me believe that the lamp and ballast are fine.
Any solutions or comments will be appreciated.
  • 7 more comments
  • Anonymous Dec 25, 2007
    same problem email me at jlc6911@hotmail.com
  • Anonymous Jan 04, 2008
    Mine began to turn off after a few minutes of viewing and gradually got worse. Eventually TV wiould not come on. Bulb is oste 2 weeks old...
  • Bullfrogj3 Feb 28, 2008
    Same here. It's getting worse as well. It will only stay on for a few minutes at a time.
  • tlhokc Mar 15, 2008
    Same problem. Red light flashing. Won't turn on. What now?
  • Anonymous Mar 18, 2008
    POWERS ON AFTER 5-45 MINS. SHUTS OFF
  • tlhokc Jul 13, 2008
    Any suggestions?
  • Anonymous Sep 30, 2008
    I have this same problem and my tv guy just left at noon. I replaced bulb and then tv just started powering up and never came on. red light indicator and then turns off. My tv man told me i need a new color wheel and digital mirror device. cost to replace both plus labor 892.30. i will keep you posted on how this turns out for me. nothing but problems with this floor model from best buy.
  • Vivian King Oct 30, 2008
    Turns ON than right back OFF! after being on for 15 seconds.
    v2kmom
  • posberg Nov 14, 2008
    TV was working fine then the sound went out. Unpluged TV and worked again. Then a day later when I turned the TV on the TV had the white lights cycling, like it was turning on and then sold red light comes on (top light) and blinking red light by the image of the bulb....what should I do?
    Problem Solver:
I called Service Care where I live they charged me $75 to come out ant $25 pick up and delivery charge. They took the television back to their shop and said they would have to order the parts needed. The tech called back and said the problem was the lamp & ballast was bad. He said the cost of repair would be $576 for parts and $225 for labor. Whew!!!!! I could just get another TV, just not another 52". Oh well......... any suggestion? v2kmom
Posted on Nov 13, 2008
Bad ballast. Go to fixyourdlp.com - or Discount-merchant.com
Posted on Sep 09, 2008
Yup, same problem here.
Posted on Feb 28, 2008
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Just replaced the lamp and the tv still will not power on. The green standby light just blinks and double clicks. No red light
HI:
Make sure you replace the lamp door or the unit will not power on. Also make sure the lamp is seated properly, Most people when they replace the lamp they try to turn on the television with out replacing the cover and think there is a problem with the set, there is a safety switch on the lamp cover door that need to be closed in order for the unit to operate.
Also you can check the self diagnostic mode, to see if any faults exsists.
With power off, using the original remote press the display key followed by the number 5 key, followed by the volume down key then hit power. You have to do all four keys within 5 secs for the diagnostic screen to come up. If all goes well check the number recorded on the right, should indicated lamp cover has been removed and if you had a bad lamp it is will record the a number of times the unit tried to light the lamp but failed. To exit press the 8 key then enter to reset them numbers to zero and do process over again and try to turn on tv normally, if it shuts down then go back to diagnostics screen and see what the tv recorder as error.
Nov 09, 2010 | Sony KDS-60A2000 60" HDTV
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
317 people viewed this question
Computer Repairing
Computer Repairing
