Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Problem for Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with...
Lots of frost in the freezer, seems like unit is
By tzdeb on Oct 10, 2009
lots of frost in the freezer, seems like unit is always running. Don't think defroster is working.
Clarification Request
Posted by akyles on Oct 10, 2009
You may be right on this. However, it may be caused by other issues, not only the defrost system.
It may be:
* Defrost timer broken
* Freezer fan broken
* Air entering into the freezer.
* A leak in the sealed system.
As only a technician can determine the exact source of the problem, it's a good idea to find how much is a new fridge and how much the repairs will cost.
Good luck.
Solution #1
posted on Oct 10, 2009
Not Rated)
milten1
Rank: Guru  Frigidaire Refrigerators  Expert
Rating: 90%, 482 votes
good call
now verify,
take off the back wall and defrost as much of the ice as you can, if you can let it defrost
other wise a hair dryer works well here
your looking for a button looking thing on the coil
two wires comming out of it
i think whirlpool uses pink and white or brown and white
any way inspect that for damge, that is your defrost terminator.
if that looks ok
ohm out you heater
it is usually one of those two things
Was this helpful?
Yes
No
Popular Solutions for Frigidaire 20.6 cu. ft. Top
Questions and Unsolved Problems for Frigidaire 20.6 cu. ft. Top
Do you recommend Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker?
Answer
Answer
i moved my refrigerator on its side and now it won't get cold...why?
Answer
I've got A Roper RT185DKXKQ00 which cools great but when it cycles on you can hear what sounds like... (More)
Answer
my frigidaire refrigerator is filling up with water at the bottom of the frig.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire 20.6 cu. ft. Top...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
