Did the pics upload successfully before the message? Regular SD cards have a tiny lock tab on the left side of the cartridge check to see if it's in the locked position if so slide it to unlock.Did the pics upload successfully before the message? Regular SD cards have a tiny lock tab on the left side of the cartridge check to see if it's in the locked position if so slide it to unlock.
You can't post conmments that contain an email address.
Their is a switch on the side oif your memory card that says "lock". switch it up. sometimes cameras push the button up to leock when you put it in. tape it if it does that
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
You need to get a memory card and promise to never use the internal memory again....it only causes problems as you have found out. When you get the new card follow this procedure:
1. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to format the internal memory.
2. Insert the new card and do the format thing again to prepare the new card.
Happy photography!
my camera Canon PowerShot SD630 DIGITAL ELPH/DIGITAL IXUS 65 out off work the lenc dsnt work bcose the battry was lowa atar the my camera stop intel now no work please inser me thank you
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Hi , in uploading picture let camera on ,plug usb , detection come in screen message , et camera button ignore it / click set camera ,select upload to camera, selection of pictures then okey.
Checklist
1. did you have a lock on your pictures?
2. did you transfer your pictures to your phone memory? (They are first stored In camera, you then manually move to the phone)
this is a solution for those who have not moved the pictures to the phone memory yet (ie it is still in camera) pictures in phone memory cannot be uploaded..
Step 1. start the camera by pressing the ok button at the center. (alternative is through the menu. left soft key. then pressing 4)
Step 2. if you have a user lock. input it now. if you did not have one then you should be on the pictures menu
notes
i) the lock is the last 4 digits of your phone by default. (if you had used the lock pictures option)
ii) if you had swapped your phone like i did and later return your cellular service to it, do not use your custom lock, rather, use the default lock ie last digits of phone number (Hope this part makes sence)
i feel that these notes are important here because this point might prevent you from accessing your pictures and since you cannot see your screen, it is important that you know what to do at step 2.
step 3. Press the digit 3 ( or - scroll down 2 times and press ok) this will take you to the third option called Online Albums.
step 4 press the down button once( this will select the option called Upload picture) and press ok.
if everything went right, you should now be in a screen called In Camera with your left soft key now called Upload and your right key called Options
Step 5 click the left soft key (Upload) do not worry about selecting the pictures since the next step will take care of that.
step 6. press the down button once. this will take you to Upload All option. press OK
step 7 the phone will ask you where to take those pics. just click OK again to take them to the default album called My Uploads
step 8 DO NOT FLIP CLOSE YOUT PHONE!!
STEP 9... there is no step 9! the phone is now uploading the pictures to your online album called My uploads just give it a couple of minutes..
Tips.
1 It would be best to do this in an area you are sure has decent network service.
2 just to be sure, please have your phone on the charger( you are dealing with pictures as well as data transfer) when i was testing out these steps, i lost a bar of my battery so just be safe..
