How can i wire 2 eletric baseboard heaters to one thermostat
  • 625 Answers
The following is a diagram of how to install two heaters off one wall mounted thermostat. how can i wire 2 eletric baseboard heaters to one  - fdcf765.jpg
Posted on Jan 11, 2008
  • JKelly
    JKelly Dec 02, 2014
    Nice of you to respond, however the diagram is very small and not clear. If I didn't already know how to do this I don't think that your diagram would have helped me to figure it out. No disrespect intended.... Best regards.
  • 4 Answers
SOURCE: i have 240 volt baseboard heater need to wire 4 wire theromostat
i have the answer, did you solved it yet???
Posted on Nov 07, 2010
  • 579 Answers
SOURCE: baseboard heater
Has it always worked like this? It seems like the wiring connection at the thermostat must be wrong for the one to work and the other one not to. Check the connections at the thermostat to make sure both heaters are wired to the output of the t-stat..
Posted on Jan 06, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 80 Answers
SOURCE: CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Posted on Oct 04, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: wwiring baseboard heaters
http://partner.dimplex.com/files/domain4103/7207610100rev00.pdf
Posted on Dec 29, 2009
How do I connect two baseboard heaters to a programmable thermostat?
You have switched 2 of the wires, reverse them.. If you had it working once, then it will work again
Apr 12, 2013 | Honeywell Heating & Cooling
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
No i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Oct 17, 2009 | Heating & Cooling
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Dimplex baseboard heater wiring
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
5,737 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
