My 20 y.o. Kenmore washing machine Model # 11082870810 is making a screeching noise when spinning. Water flows in and out fine. I smell something either burning or hot. The washer will then stop and but continue to buzz until I turn off the machine. Is it the motor or the drive. If so, how do I check each one to see if it is working properly or not? I took off the motor to see if the plastic and rubber coupling parts were severely worn, but to my amazement, the parts were only slightly worn. Could that still be the cause? Thank you for your help. P.S. Do you know the cubic feet capacity of this washer?
If both things have something to do with one another. It sounds like a bad motor. When you removed the coupler, did you notice if the part that goes over the shafts might have been cracked. If one is, it will spin on the shaft. But the motor keeps coming up when I read your description.
Testimonial: "Great service and advice! I was answered literally in minutes! Thanks again!"
Thanks for your reply. The couple was in good shape and was not cracked, in fact it was very tight on the shaft.
Is there any way to check the motor with an ohm meter to verify it is bad?
