Question about Canon ImageRUNNER 330s Copier
Fire Department we recived this copier as a hand me down from our city hall. we would like to use it as a printer as well. is this possible
  • Canon Master
  • 1,113 Answers
Yes you can there should be a network ethernet port in the back plug in and configue to network
Brochure
specs
Copier Std Internet Fax No Network Printer Std Printer Std Fax Opt Network Fax Opt PC Fax Opt Scanner Opt CONNECTIVITY SPECIFICATIONS Operating System Support Mac, UNIX, Win 9.x, NT 4.0, 2000** Parallel Interface Std (with opt controller) PC Fax/Print/Scan Yes/Yes/Yes Serial Interface None PC Fax/Print/Scan Not applicable USB Interface None PC Fax/Print/Scan Not applicable Network Interface Std Ethernet, opt Token Ring Interface Type 100BaseT, 10BaseT, 10Base5 LAN Fax/Print/Scan No/Yes/No Networks Supported NetWare Yes Windows NT Yes AppleTalk Yes UNIX Yes AS/400 No Other None
Merry Xmas
Posted on Dec 26, 2007
I need to find phone number of a person who lives in Warsaw. I have a name and an address
The following states have towns named Warsaw.
Which is your wish?
Georgia
Illinois,
Indiana,
Minnesota,
Mississippi,
Missouri,
New York,
North Carolina,
South Carolina,
Texas
Fixya has no phone directories.
You will need to call someone in Warsaw for help.
Try the city hall or the police department.
God bless your efforts.
Jul 28, 2017 | Cell Phones
Can a volunteer fire company refuse to put a fire out at your home if you dont donate money
Absolutely not. That's nothing more than a scam. I suggest that you contact the Mayor's office in your city/town and advise them if you have had that experience.
Apr 06, 2017 | Computers & Internet
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Mar 16, 2011 | Samsung SCX-6322DN All-In-One Laser...
Xerox 425dc service code
Hi.
The 425 dc error code refers to the department code assigned to the printer.
425 means that you have entered an invalid department code.
to fix this, you need to turn off the department codes
To do this, press the menu button so that it says machine defaults
then use the arrow down scroll button until you get department codes, then press enter
Scroll down to select off, and then press enter again.
Now press the features button to return the printer to a ready state.
You should now be able to print on the copier again.
I hope this helps you out.
Feb 08, 2011 | Xerox WorkCentre Pro 416Pi All-In-One...
We have a hp officejet G55. Why can we not get the scanner to work. It use to work and, noe it does not The Printer works.
I feel I recived some wrong advise and, feel I should be able to recive my $19.99 back. I talk to Chapli about the problem I was having with my printer. I told him I have a office jet g55 and the scanner does not work. I told him the copier, and the printer do work. He told me that I need to replace the white cable that goes to the scanner, Because it was deffective. He said it would cost about $20.00, and another $40.00 for tech support to walk me through to replace it. So me and a friend who has alot of computer exprencie took the printer apart, and found out that all the cables are togher. I called HP to order the part, and they told me that you can not replace that part that I would need to bye a new printer. Which we did a 6480 model. So all the time that it took to take printer apart and the bad advise I feel I should be able to get my money back. The order department said the tech should have know this and he gave me bad adviser about replacing cable.
Thanks Gary
Jan 16, 2009 | Office Equipment & Supplies
Our fire station has a cat5e cable supplying internet access to our internal network from a switch in city hall. It connects a baystack 350 to their switch. If this cable is left plugged in during the...
Very likely an IP problem. The server in City Hall is most likely doing the DHCP assignments for all connected machines, and if there is a LAN server running DHCP also in the firehall, there will be a conflict, which may not manifest itself until the assigned IP leases expire and renew. If this is the case, try a router WITH DHCP DISABLED between the two systems, WAN side toward City Hall. As a quick test, disconnect the cable and run IPCONFIG on a firehouse machine. Note the IP, it should begin with 10, 172 or 192. Reboot the machine, run IPCONFIG again. If the IP comes back, you have DHCP running on something. If you see something like 169.254.???.??? you do not, in that case try hooking up a router configured just as it comes from the box. If anything in the firehouse is wireless, making connection thru a wireless router, the problem may be a simple miswire. WAN side toward City Hall and one of the ports toward your switch, don't use the other three. May need to use the uplink port or a crossover cable between router and switch. (Network admin by day, DJ by night)
Sep 11, 2008 | Computers & Internet
201 people viewed this question
old marine
old marine
