Gateway MX6448 PC Notebook
Problem for Gateway MX6448 PC Notebook
MX6448 won't boot; black screen.
By marejohnlink on Oct 10, 2009
I've had my MX6448 for five years. My kid uses it every day, always with the power supply plugged in, not on battery power. The battery is the original; it's never been replaced. Today my kid used the notebook for several hours. He generally does not power off after use, but lets the thing go into Standby. I returned to it several hours later to find a black screen, with the front left blue light on (Battery?) . I tried turning it off/on, using the usual button at the top right of the keyboard, but all I got was the right front blue light (HD?)turning on for a few seconds. It then went off. The Battery LED remained blue. A geeky mousepad displayed its startup colors for a few seconds. The red LED on the optical mouse pulsed. The screen remained black. Nothing else happened. I tried pulling out the power supply plug and waiting. When I did that the Battery light went black. When I put the power supply plug back in, the Battery light went magenta, then blue after about a minute. But startup still failed. Any advice?
Comments:
Nov 06, 2009
- Just after I originally posted my questionm the notebook came back to life, so I didn't check the comments here. But the problem happened again, so I came here to see if anyone had originally responded. I was not aware of the need to remove the battery pack, and had never done so! When I took it out I was immediately able to reboot using only the a/c adapter. I am hoping that all I need is a new battery, and don't have to replace the power strip as well. I'll see how things go. Thanks for your advice!
Best Solution
posted on Oct 10, 2009
Very Helpful)
DesertDeuces
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 41 votes
It seems that you don't remove the battery when you use the Notebook. This practice shortens the life of the battery because, when you use the a/c adapter and the battery, your battery is alternately charging and discharging all the time. The cells in the battery eventually die.
From what you describe, it sounds like the power strip inside the Notebook (where you plug in the adapter cord) has been damaged and needs to be replaced.
Your computer is not a total loss. Just have that power strip and the battery replaced and your Notebook should be up and running again.
And, in the future, if you just remove the battery when your kid uses the computer, or if you are going to be using it for over 1 hour. Save the battery to use when you need the mobility.
Comments:
Nov 06, 2009
- Hi,
I'm very glad you got it going. The nice thing about laptops is that many of the repairs are easy to do, so don't be too frightened about maybe needing to replace the internal power strip if it comes to that.
I really hope that all you need to do is replace the battery. Good luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Gateway MX6448 PC Notebook
Questions and Unsolved Problems for Gateway MX6448 PC Notebook
Do you recommend Gateway MX6448 PC Notebook?
Answer
Answer
HI I have an Enpower laptop wih the model # AN5 and has windows xp. i was hoping you could tell me... (More)
Answer
L35-S2171, Monitor screen will not light up. Screen is new, inverter is new. I can see images when I... (More)
Answer
fills all text bars with $ For example, in the search bar, it will fill up the seach bar with... (More)
Answer
My web camera wouldn't go on just now when I was talking to someone on skype and so they couldn't... (More)
Answer
My nephew bought a refurbished Gateway MX6448 Notebook about a month ago. He says the pointing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gateway MX6448 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
