Question about Nikon N55 35mm SLR Camera
Fee to error
My nikon n55 had the fee message turn up so i changed the aperture to f=22 but now instead of fee, err keeps flashing every time i take a picture
  • 667 Answers
Remove the batteries for 5 or 10 minutes. Remove the lens from the body and replace it. Make sure the lens is on f22 before you put the batteries back in and turn on the camera. If this doesn't solve it, try rewinding the film you have in the camera and try a new roll. The other thing to check if none of the above works is to remove the lens and check the small tab just on the outside of the mount ring at about 7:00. The tab is spring loaded and you should be able to push it with your finger and it will snap back. If it doesn't, the tab plate will need repaired or replaced
Posted on Dec 26, 2007
Why is my NIKON n55 flashing fee
You need to turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it in place if the lens has an aperture lock.
You control the aperture from the camera, the same was as on a lens without an aperture ring.
Nov 20, 2011 | Nikon Photography
I have copied and pasted someone elses problem, because it is the same one I am having. So if I want to use the aperture for taking Manual photos I cannot do this because when it goes off of F22, it reads...
Lock the aperture ring at its smallest opening (in this case, F22). Change the aperture setting by turning the subcommand dial (the one in front, unless you changed it in the setup menu).
Of course, you can only change the aperture directly in Manual and Aperture-Priority modes.
Mar 23, 2010 | Nikon D80 Digital Camera with 28-80mm Lens
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
Nikon d70
That means your lens is not set to the smallest aperture - f/22 or f/36. Turn your lens aperture ring all the way to set the smallest opening. Then the error will go away.
Jul 03, 2008 | Nikon D70s Digital Camera
Nikon n55 film camera
You must have your lens set to the minimum aperture setting for this camera to function. I.E. f22,f32. The aperture ring moves a small tab on the outside of the mount ring when in that position.
Jan 13, 2008 | Nikon N55 35mm SLR Camera
My camera won't do anything but flash the Err message
Make sure the lens you are using on the camera is set to the minimum aperture setting. i.e. f22,f32 (highest f stop number)
Dec 28, 2007 | Nikon N55 35mm SLR Camera
Flashing Err and E/Error Problem
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 17, 2007 | Nikon N55 35mm SLR Camera
FEE error message
To get rid of the pesky fEE just set your lens to f22 or f16 ( depending on what lens you have ) and that is all. You might also want to lock this setting in ( if it is a Nikon lens then the lock is on the side just above the lens aperture ring.
Dec 07, 2007 | Nikon N55 35mm SLR Camera
Err message
If the error message is on the left hand side of your LCD monitor then your shutter is not coming on line and it might be the 'reset' switch in the back cover locking mechanism that needs replacing. If the error message is on the right hand side of the monitor then this is because the F - stop on your lens is not set to highest setting ( 16 or 22 ) . Set your lens to highest setting and check again to see if error ( FEE ? ) disapears.
Sep 21, 2007 | Nikon F65 35mm SLR Camera
Nikon N55 35mm SLR Camera Logo
134 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
