Question about Logitech MX Revolution 931689 Mouse
Installation I just got the MX Revolution for Christmas and tried hooking it up to the computer and using it, but it doesn't seem to connect. The computer registers that its there and the correct drivers have been installed and it says that it is ready to use. The problem is, the cursor doesn't move and it doesn't seem like it is connected. It came with a charger, AC adapter, and a USB adapter. Should I have gotten some kind of software cd with it and a user manual?
  • 3 more comments
  • robbydcowboy Dec 31, 2007
    i just got the reolution, and i charged it and tried installing softwhere from the net... but it doesnt work, i can not even get the lazer to shine.... how do i install this mouse??
  • Anonymous Jan 19, 2008
    The mouse doesnt work
    I downloaded the software and my mouse still wont move any suggeions
  • Anonymous Feb 18, 2008
    I have the same problem. I downloaded the software, the mouse is completely charged, control panel recognizes that it is there, but the cursor does not move. I also tried the possible fix of holding the left click button down, turning it over and switching it off and back on, and clicking the right click button five times. There is absolutely no response.
  • harro87 Apr 13, 2008
    yep pretty much same problem. i actually bought the whole mx5500 set, the keyboard still works, even the mouse BUTTONS still work, but the cursor just won';t move. Interestingly it worked straight out of the box and died a few days later. It's charged, set point is installed etc etc but no luck.
  • 70 Answers
Http://www.logitech.com/index.cfm/428/130&cl=in,en?osid=1&file=
You can download the relevant software from here. Select your relevant Operating System.
Posted on Dec 25, 2007
Logitech mx revolution
Hi
Maybe your registry is not clean. You can use registry fixing software and then run registry analyze. and restart your computer.
Jan 19, 2014 | Logitech MX Revolution 931689 Mouse
Back button, forward button does not work on my mx revolution mouse
Problem was solved by remove usb connection and reconnecting. All buttons work now. Thanks
Nov 03, 2009 | Logitech MX Revolution Wireless Laser...
Keyboard keys not working, sluggish mouse
You might need batteries. Manufacturer-supplied batteries are frequently low quality. So, try that.
Oct 16, 2017 | Logitech Cordless Desktop MX 5500...
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
New mouse wont connect....
This is a common problem, go to the Logitech website (www.logitech.com) and download the Reconnect utility. Follow the steps given to you in the software and it should work fine! If not, is the mouse fully charged?
Nov 10, 2008 | Logitech MX Revolution 931689 Mouse
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
I have an unexpected problem. Yesterday I installed MX Revolution Mouse. Eveything was fine until I attempted to replace blank entries in MS Access Database fields. The progam keeps informing me that...
LIFO - Last In, First Out
First uninstall the software and reboot. Does it work now? If it does, it is definitely the software. If it still doesn't work, then it's not the software. Then post your findings and we'll go from there.
Please remember to rate this soltuion!
May 07, 2008 | Computers & Internet
Mx revolution mouse
make sure it's clean where the light sensor is. Dustbust it or something. otherwise I'd say it's dead.
Jan 31, 2008 | Logitech MX Revolution 931689 Mouse
Logitech MX Revolution 931689 Mouse Logo
169 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
