Question about Pioneer PDP-4270HD 42 in. Plasma Television
How to unlock my 42 plasma
My 4270hd plasma is locked what is the unlock code
  • binder99 Dec 25, 2007
    how to unlock my pdp4270hd pioneer plasma tv
  • Adam Wordsworth
    Adam Wordsworth May 11, 2010
    What do you mean 'locked'. Please be more specific.
42inch lcd olevia TV m-242-511 blue light stay's on
The main board fault. Contact the authorized service centre for Olevia.
Gopakumar Gopalan Google
Apr 01, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
No picture, red light on side of tv blinks 5 times in a row
Swens, not positive what your issue is. But, give a company named ShopJimmy.com a try for replacement parts. I have included a link to your model page from their site. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=PDP-4270HD
Sep 20, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
My pioneer pdp-4270hd television wont turn on. i used it for 8 months. Then it sat standing right side up im my house for approximately 2 years. i just moved and rehooked everything and when i plugged it...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
May 21, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Good remote control doesnt work in the tv
IF you haven't replaced the batteries it may just be the age of the remote although in good condition to the eyes, maybe you should consider getting a universal remote, it comes with a manual and a list of codes and instructions on how to program it on your TV.
Feb 27, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
Error message
i have the same problem. Has anyone found a fix?
Dec 15, 2007 | Pioneer PDP-4270HD 42 in. Plasma...
Pioneer PDP-4270HD 42 in. Plasma Television Logo
217 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
