Question about HP Pavilion dv9000z Notebook
HP Pavilion DV9009us does not boot
I've tried the suggestions on the HP web site with no luck. The power led come on, the DVD control leds come on, the DVD player green led comes on briefly, then all leds blink on/off quickly then back to steady on. No whirling sound from the hard drive though.
  • 1 more comment
  • kevcass Dec 25, 2007
    Sorry if I was not clear. The PC does not boot at all. I tried the suggestions on the HP web site, re-seating the DRAM and hard drive with no change. I've pressed F2, delete, F8, and F10 each with no response. The screen is blank, no HP logo. The hard drive LEd binks on once and goes out.
  • kevcass Dec 29, 2007
    Fortunately the PC was still under its 1-yr warranty. HP FedEx'd an empty box for me to return the PC to their repair center.
    I'll let you know if HP reports back what the problem was.
  • kittiwake May 28, 2008
    This sounds like the same issue we are having. When the power button is pressed, the control lights light up for approx 1 second, then go out. If I press the DVD button, the same thing happens. It makes no difference if the AC cord is plugged in, and I have removed the battery overnight with no change. No key combination, or function key has any effect. The screen does nothing.
    Sergeant:
  • 263 Answers
Check if the internal batery is ok that may be the problem or your motherboard but loock for the batery first
Posted on Dec 29, 2007
    Sergeant:
  • 239 Answers
I not sure what your saying, Is it the laptop thats not working ? Or DVD drive ? If Its the Pc Try and get into you Bios, Are you able to see the Hp Logo when you first turn power on, Or is Absolutely nothing Happening, No screen at all. Try and make sure, may be someone set it down a little harder than normal and may have jarred the Memory Module loose, Or even the Hard Drive it self may have become loose try to remove the Hd screw and remove and reset firmly back into place, If not, Just a little more Information may help us out, Thanks and I hope this works for you. bear001 Oh yeah If you can see the Hp logo, when you see that repeatedly push the F2 key or the Delete Key until your bios opens and try and reset back to Default Settings,
Posted on Dec 25, 2007
  • bear001 Dec 25, 2007
    Ok try when you power up holding the ALT,CTRL,DEL Keys all at the same time and release them and see what happens, Also Try and see if you can get the CD/DVD to open up when powering on. see if there may be something stuck in the drive, Also did you try it with just the battery, and no power cord plugged in, try that too, if that don't work I will do some more intense research online for you and find out what in the heck is going on. if you have to clear cmos or what, sorry about you problems but I will try to solve if that don't work for you, you may also try holding the power button down for 10 to 20 seconds, I sure hope that gets you going ,
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
How do i fix my LCD?
I have got a hp pavilion dv5000, when I turn on it the screen goes blank.
Power led glows, I hear for a few time the fan, disk led flashes intermittently and also I feel that the DVD player tries to load.
If I try to click on caps lock or num lock, leds don't respond to commands. I tried the hard reset pressing the power button for 30 seconds with the battery and the power removed. Nothing to be done by connecting an external monitor....
Thank you
Jun 11, 2013 | HP Pavilion dv1000 Notebook
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Hp pavilion dv2000 notebook will not boot up
Try un-install memory chip and re-install again.
Nov 16, 2008 | HP Pavilion dv2000t Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Nov 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv9000z Notebook Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
