my hl 5150D will not print. when isend document to printer green print stays on but nothing happens. shortly thereafter i get an erro message saying that somethig is wrong but not what. sometime toner lights come on but nothig else happens when i send document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Was this helpful?
Yes
No
Popular Solutions for Brother HL 5150D Laser Printer
Ever since changing the drum cartridge, the copies are now very dirty w/black spots. I've tried...
(More)
Ever since changing the drum cartridge, the copies are now very dirty w/black spots. I've tried cleaning it prior to and after installing the cartridge.Any suggestions?
brother hl 5150d when printing off documents the back ground of the paper has all black lines and...
(More)
BROTHER HL 5150D WHEN PRINTING OFF DOCUMENTS THE BACK GROUND OF THE PAPER HAS ALL BLACK LINES AND SPOTS ON IT I HAVE BEEN TOLD IT COULD BE THAT I NEED A NEW DRUM THE MACHINE IS ABOUT 2 YEARS OLD CAN YOU PLEASE HELP
I had a paper jam - cleared it, but it was difficult...paper tore into pieces. Now the printer gets...
(More)
I had a paper jam - cleared it, but it was difficult...paper tore into pieces. Now the printer gets a paper jam every time I try it. It picks the paper up and about an inch in it jams again. I can't use it. I think I have to take the printer apart. Tell me how PLEASE!!!! Thank you.
I have a 5150 D Brother laser printer and it won't feed the paper through. What could be the...
(More)
I have a 5150 D Brother laser printer and it won't feed the paper through. What could be the problem? It seems like something is just not catching properly to grab the paper. Thanks, Jess
PF Kit 1 shows needing repalcement. I repalced it, and need to reset the internal counter for the...
(More)
PF Kit 1 shows needing repalcement. I repalced it, and need to reset the internal counter for the printer itself. It is still showing 0, and not allowing network printers to prnt. The only PC that can print, is the PC directly connected to printer. When we attempt to print for the network printer, nothing happens, and the paper jam light comes on, and the printer locks up, and eventually prints its test settings page, stating that PF Kit 1 is at 0. I have tried the drum counter reset. I have tried holding go, and powering on, let go on toner light, then hold go again, and let go on paper light, per the factory to do a factory reset. Tried the same process with lettign go on drum light, and also lettign go on the paper light, and also lettign go on the status light while in yellow, and also letting go while status light was on green. None of them did a complete factory reset, and the support at brother told me to call a printer shop. Print setting page (go x 3) still shows PF Kit 1 at 0 pages left allowed.
