Epson Stylus Photo R1800 InkJet Printer
Problem for Epson Stylus Photo R1800 InkJet Printer
The message says parts inside the printer are nearing the end of
By btaylor394 on Oct 09, 2009
The message says parts inside the printer are nearing the end of their service life. What should I do?
Best Solution
posted on Oct 10, 2009
Very Helpful)
michael_grey
Rank: Guru
Rating: 85%, 149 votes
This message means that the printer thinks the waste ink pads are full and so
> it refuses to print until the pads are replaced and the waste ink (protection)
> counter is reset.
> In practice the pads will not be full if this is the first time you have
> received the message so all that needs to be done is to reset the counter. Next
> time you must replace or clean the pads.
> Go to http://www.ssclg.com/epsone.shtml and download the utility.
> Install it, run it and exit it from the main window, now go to the icon in the
> system tray and right click on it. Select waste ink or protection counter and
> select reset. If this gives trouble then uninstall the Epson status monitor and
> try again (you can install the status monitir again afterwards).
> The irony is that the more you use an Epson printer the more reliable it will
> be (due to the heads being kept in good condition) but the people that use
> their printer most will get this message earlier than others. Some people never
> see this message. It is a good printer and well worth the effort of doing this
> at no cost.
> Tony
> MS MVP Printing/Imaging
The SSC service utility won't reset the R1800 counter.
The Epson service program is needed and can be downloaded from:
http://www.2manuals.com/
The R1800/2400 service manual can be downloaded from that site.
If you want to have a go at replacing the pads, then instructions are in
the manual.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" good advice- thanks much. Saved me service call " - btaylor394
Popular Solutions for Epson Stylus Photo R1800
Questions and Unsolved Problems for Epson Stylus Photo R1800
Do you recommend Epson Stylus Photo R1800 InkJet Printer?
Answer
Answer
The light above the Cyan cartridge keeps burning.Also the red light on the "ink press button... (More)
Answer
Color photos print darker than how they appear in Lightroom 2.0, using the Epson-supplied profile... (More)
Answer
paper wont feed, power on and in a minute or so 2 red lights flashing red. R1800. does it with and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus Photo R1800...:
Top Printer Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
