Home | Sony | Handycam DCR-HC30 Mini DV Digital Camcorder | Touchscreen is ino...
Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Problem for Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Touchscreen is inoperabable
By edsam17 on Oct 09, 2009
when I open the touchscreen it automatically defaults to the clockset mode and nothing happens when I touch the screen.
Solution #1
posted on Oct 10, 2009
Not Rated)
Luwangula
Rank: Wiz  Sony Expert
Rating: 81%, 26 votes
This fault is often caused by a failing flat cable that connects the LCD panel and the rest of the camera. In its early stages it is possible to get the buttons on the touch panel to work by carefuly changing the angle of the LCD panel while trying out the buttons until you get a position where they work.
When the flat cable gets worse , the picture on the LCD panel will start deteriorating and go off altogether.
At this stage you may consider having the flat cable replaced
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam DCR-HC30 Mini DV
Questions and Unsolved Problems for Sony Handycam DCR-HC30 Mini DV
Do you recommend Sony Handycam DCR-HC30 Mini DV Digital Camcorder?
Answer
Answer
When you try to record, it gives a beep beep beep about 4 times and a small orange light appears. I... (More)
Answer
on both the lcd screen and the viewfinder the image is all screwed up with lines up and down the... (More)
Answer
i have a handycam dcr-hc32 that the screen got red could i get fix
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam DCR-HC30 Mini DV...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
