Question about Microsoft Windows XP Home Edition
Converting in order to Resizing an NTFS partition...
I keep hearing about using Diskpart.exe to make my partioned drive bigger. However, I also learned, in order to use this tool I should have FAT not NTFS.
Is it possible to convert the NTFS to FAT and then use the diskpart.exe tool? Then, once I've increased the size of my partition can I simply convert the FAT back to NTFS?
Or does it even matter which one I have?
  • ntech26 Dec 25, 2007
    Thanks for the info. I did not know NTFS was better than FAT. After googling, I found out making my partition bigger is very easy and straightforward using FAT (at least this was my non-techie understanding). That's why I was asking about converting. So, thanks for steering me in the right direction on that one :) NTFS it is!
    However, after reading what you wrote it's obviously better to stick with the NTFS and merging my 2 partitions. Unfortunately, I am VERY unclear as to how I do that. If you could tell me step by step (if it's not too long of a process for you) or direct me to a website that will tell me step by step how to do it, I'd REALLY appreciate it.
    Thanks again for the quick response!
    Scholar:
  • 103 Answers
The only way to make your partion bigger is too merge your partitions.
The way the partition is formatted. (ie. FAT, FAT32, NTFS, etc) allows for information to stored differently. These file allocation tables use different size slots to store the information in. When you install a new program, the data is put into the first empty slot on the drive, and if there too much data for 1 slot, it uses the next available empty slot and so on until all the data is stored. If the last bit of data is just a couple of bites. The remaining space is unusable for any other program, thus wasting space.
When you delete a program, those slots are emptied and the next time you install something, it is stored in the first available empty slot. SInce most programs are not the same size, your drive soon becomes fragmented and this slows down the way the OS is able to retrieve information. (That's why defraging is a good thing.)
So using smalller allocated table sizes makes more efficient storage (less wastage of space) but on large drives this also makes for slower retrieval times and makes the OS work harder.
But to answer your question, you cannot easily convert NTFS to FAT,and I don't understand why you'd want to go to FAT from NTFS anyway. NTFS has much better security (FAT has none) and is more efficient than FAT.
But to convert to FAT you would need to do the following:
BACK UP YOUR DATA FIRST/
Then delete the partition that you wish to convert. This is done by going into Disk Management: right click "My Computer" -> Manage -> Disk Management, which is found under the Storage section. Right click the partition you wish to remove, and click "Delete Volume". This will erase the partition. Once you have done this, you must re-create the partition. This is done by right clicking on an unallocated region of a disk, and selecting "Create Partition". Then click "Create Logical Drive". Bear in mind that Windows cannot format a FAT32 partition that is any larger than 32GB. This is the case because FAT32 is terribly inefficient on volumes that are larger than 32GB: fragmentation becomes a serious problem.
To format this new volume, right click it, and choose Format. Again, if the volume you wish to format is larger than 32GB, FAT32 will not be one of the options available to you in the drop-down box. You will have to create multiple partitions if you want to format a large drive as FAT32. (Oops, there goes the reason you were doing this in the first place)
You would be better off just leaving it alone, and if you must have a bigger drive, either buy a larger drive, or merge 2 partitions. (Using the above method to do so)
Hope that helps.
Posted on Dec 25, 2007
  • Terri Bates
    Terri Bates Dec 26, 2007
    Before starting, Back Up All of the partitions you are going
    to merge, as you will be deleting everything on them.
    I would not advise you to merge or delete your primary
    partiton, "Drive C" If you plan to do this to drive C, you
    might as well, just re-install windows and start fresh.
    1. Right-Click on the “My Computer” icon either on your desktop or in the Start Menu and select “Manage.”
    2. A new window titled “Computer Management” comes up. Select “Storage” from the left hand side by clicking it once, then select “Disk Management(local)” from the right side by double-clicking it.
    3. Now in the lower part of the main frame (right side) of the window you should see a nice visual of all your hard drives. Each line is a different drive. Each box on a line (with a colored bar at the top and a size displayed in MB or GB) is a partition on the drive. Partitions are separations of space on a drive.
    4. First you must delete the existing partitions you want to merge. Do this by right-clicking on the partition's box and selecting “Delete logical drive...” Since you already know that you will be deleting everything on the drive, and have already backed everything up, you can safely say yes to any warning the computer presents you with.
    5. Then repeat the above step for each drive you want to merge. If you only want to merge 2 partitions that is OK and you can continue to the next step without deleting the other partitions.
    6. The box for the drive to be formatted should now have a black bar at the top of it and should say “Unallocated” under its size . Right click on it and select “New Partition...” The New Partition Wizard comes up.
    7. In the New Partition Wizard click next. (If one of the drives you deleted was the primary partition on the next page make sure “Primary Partition” is selected and click next.) If it was not a primary partition select "Logical Partition" Now make the size equal to the maximum (it should already be set to it), and click next again. On the next page the computer will automatically choose the first available drive letter for the new drive. However, if you like you can choose another drive letter from the drop-down menu, and then click next.
    8. Finally the New Partition Wizard asks if you would like to format the new partition and if so what format. Choose “NTFS” as it is faster and more secure. Leave the “Allocation unit size” as “Default.” In the “Volume label” field enter whatever name you want the drive to have. Simple is better. Avoid using spaces. Do not check the “Perform a quick format” box or the “Enable file and folder compression” box and click next. Then on the next page click finish.
    9. The wizard will now spend a little while formatting the drive. Do not close the “Computer Management” window until it finishes. You will know it is done when the word under the size of the drive changes from “Formatting” to “Healthy” and the name and drive letter you chose for the new drive show up. After it is finished you can proceed to use your newly formatted drive.
How to change hard drive ntfs format
Boot the windows installation media and go to the repair section of the installation media and select command prompt.
run these commands individually one after the other:
diskpart
select disk 0
clean
create partition primary
format fs=ntfs quick
active
assign
exit
once you have exited the diskpart service you can restart the installation process from the installation media.
Beware... If the hard drive you are formatting to NTFS currently has an existing file system or other OS loaded onto it then that information will be deleted (most likely irreversibly. Since you have a GPT disk at the moment that tells me that you most likely have Windows 8 installed on that particular device. Windows 7 does not install on every device that has Windows 8 preloaded. You may also have to go into the BIOS and disable the security keys associated with that drive and OS.
*Proceed at your own risk and I do not accept any liability from these or any other tips provided in this or any other posts. All computer repairs dealing with DATA are and can be inherently risky if you are not well enough trained to do it properly*
Apr 12, 2014 | Toshiba Portege Z930-S9302 : Ultrabook -...
Tip
Hide Your HDD Partitions Hide your HDD partitions 1. Go to Start > run...
Hide Your HDD Partitions Hide your HDD partitions 1. Go to Start > run > type “diskpart”.
a dos window will appear with following like that
DISKPART> 2. Then type “list volume” without quote
It will look like this.
Volume### Ltr Label Fs Type Size Status Info
Volume 0 F CD-ROM
Volume 1 C NTFS Partition 7000MB Healthy
Volume 2 D soft NTFS Partition 8000MB Healthy
Volume 3 E —- NTFS Partition 8000MB Healthy
3. If u want to hide drive E then type “select volume 3′ without quote
then a message will appear in same winwods { Volume 3 is the selected volume}
4.now type ” remove letter E” without quote
now a message will come { Diskpart Removed the Drive letter }
sometime it requires the reboot the computer .
Diskpart will remove the letter .Windows XP is not having capabilty to identify the unkown volume.
Don’t afraid ur Data will ramin same .
to Come back the Drive repeat the process . but in 4th step which is shown in this post replace ” remove” to “assign
means type ” assign letter E” without quote
The above method won’t work for the drive containing Operating System and it can also be done using System Manager>Storage Manager
on Jan 26, 2010 | Computers & Internet
Unknown capacity usb
Run CMD.EXE as administrator
Type following commands and hit ENTER key after each command.
· DISKPART starts the DiskPart program
· LIST DISK shows numeral assigned to disks
note the numeral assigned to your usb stick
The numeral 2 will be used in this example
· SELECT DISK 2
· DETAIL DISK the info shown will confirm the correctness of your selection
· CLEAN ALL the entire usb stick will be overwritten with zeros
· CREATE PARTITION PRIMARY create a primary partition on the USB stick
· FORMAT FS=NTFS format the partition
· ACTIVE the partition can contain operating system startup files
· ASSIGN the next available letter is assigned to the USB stick
· EXIT exit from the DISKPART program
· EXIT exit from the command shell
Nov 08, 2013 | SanDisk Electronics - Others
I have a IOMEGA 1TB hard drive, and I formatted It and it gives me only 92.7MB free out of 92.8 MB and not the full 1TB and I'm using on my PC windows 8 pro and It won't back up all my files what do I do?
I would connect drive and from dos prompt run diskpart. Make sure you have extended dos partition that has the entire drive space. You can type at the dos prompt: diskpart ? for help. Once you have partitioned the whole drive format it with NTFS.
Oct 25, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
I am trying to use a WDC WD80 0JD-00MSA1 scsi hard drive through a DOCKMASTER Kingwin USB connection and device driver sees it and a BELARC Advisor scan sees it but not My Computer. The drive is unused...
You mentioned that you have never formatted this hard drive. Has this been FDisk and Partitioned? If the hard drive has never been Fdisk / Partitioned / Formatted, this will not be recognized in the windows environment.
You can use DISKPART in command line to manage and partition your hard drive. After formating it in your preferred format (NTFS is recommended). Your hard drive should display properly in windows explorer.
Hope this helps.
Apr 30, 2011 | Computers & Internet
I want to install ubuntu and Mandiva, my question how to Install both operating systems? Thanks
The answer is yes, and no.
Both Mandriva and Ubuntu are Linux based and they do have
similarities and differences. The differences in how things run
may cause you problems, so the easy answer is no. There are
similarities that can be shared, and in this case, you have a
yes.
Since you mention XP and Ubuntu halves above, I'll assume you
have your harddrive split in only 2 partitions, perhaps or
preferably 3 partitions, such as.
hda1 = C: = XP ntfs (maybe 15 to 40 GB in size)
hda5 = extended partion which holds Ubuntu and swap
hda6 = = Ubuntu (maybe 4 GB or bigger and includes home)
hda7 = swap (approximately 2x the size of your RAM)
First, we begin by describing your hard drive geometry.
When IBM compatible PC computers came into existence, the hard
drives had definitions allowing the harddrive to be divided into
4 separate partitions. 1 of the 4, could be allocated as
an "extended" partition which could be divided further into many
more partitions. In the past, this allowed you to have 4
distinctly different operating systems on your harddrive, or 3
distinctly different operating systems and an extended partition
for extended drives, so in the past, it was possible to have
combinations such as DOS, Win95, OS2, and shared extended drives.
There were additional limitations, but based on you
describing "halves", your computer does not have the 1024
cylinder problem of long-ago and you are running a more modern
computer with a modern BIOS.
XP does want to be the 1st operating system on the 1st
enabled "primary" partition, so let us leave that as it is since
linux is more flexible and can be put on the extended partitions.
From a linux perspective, the primary reserved definitions would
be 1,2,3,4 (XP will me located in one of these 1..4) and the
extended partitions are 5 to define the partition, then
6,7,8,9.... (your Ubuntu will be located on one of these 6...).
Due to some very old software having had problems in the past,
you will want try to keep within the boundaries of 6,7,8,9 to
avoid problems (unless you are an expert at troubleshooting).
In linux, you may note that your hard drive is described as hda
or perhaps sda and a number.
If you type at the command line fdisk /dev/hda and then
choose "p" for partition definitions it should describe how your
hard drive is partitioned right now. Press "q" to exit.
I'll assume you do not know about moving and remounting
directories, so we'll go the easy way with more steps but less
chance of problems.
If you have not done anything particularly important on your
Ubuntu worth saving yet and don't mind reinstalling it, I would
recommend putting the /home in a separate partition which you can
share between Ubuntu and Mandriva, and also a separate /swap
partition that can also be shared. If you need to keep certain
things, then make a backup of what you want to keep and put those
aside to restore later. This is better done now before you
install Mandriva. We want to avoid some complicated moves later.
I prefer to backup my machine before causing some major changes
such as these, it is strongly recommended you find a method to
backup your computer at the hard drive "image" level so you can
recover from a disaster if something goes wrong. this may help if
you have another computer available with sufficient hard drive
space. Substitute windows "share" instead of Samba if the other
computer is windows based.
http://www.joescat.com/backup/disk_image.html
If the above does not work for you, just make sure you make a
backup you can recover from one way or another.
With your Ubuntu install CDrom divide and install your Ubuntu
somewhat like this (partition #s and sizes may vary)
hda6 = home = Ubuntu (to share with Mandriva, make it
sufficiently large)
hda7 = = Ubuntu (maybe 4 GB or bigger, does not have home)
hda8 = empty partition (same size as hda7 - not defined)
hda9 = swap (approximately 2x the size of your RAM)
I recommend in the order above since you should rarely if ever
need to use /swap (so it is at the very end of your harddrive),
and your /home is next to your XP C: partition, which allows you
to change and modify everything in between your /home and /swap
without having to modify your XP C: /home or /swap any more.
Next, get your Mandriva CDrom install disk, and begin installing
it, during install, you want to re-use the existing Ubuntu /home
and existing Ubunt /swap partitions, so you indicate during
install:
hda6 = home = Mandriva (to share with Ubuntu)
hda7 = leave as undefined (it is your existing Ubuntu ""
hda8 = = Mandriva
The values 1,6,7,8,9 may not be the same as they are assigned by
the partitioning tool, but the locations on the disk should be in
that order. Mandriva has resizing and partition moving options if
the partitions need to be re-sized, I think Ubuntu also includes
similar tools too. After finishing, run XP and do a command-line
chkdsk C: to make sure XP is happy with any changes you may have
made to XP's partition.
You should now have XP, Ubuntu and Mandriva with a shared /home
partition and a shared /swap partition. thanks
Mar 10, 2011 | Computers & Internet
I want to format my 2 T hard drive from NTSF to fat 32 , how to do please help
Ok this fix will erase all Partitions on the drive, Make sure you have all data back'd up.
Open Command:
Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator. Or Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
You should have a black MS-DOS prompt on your screen. Type DISKPART in and press enter. Another window will open
Type: list disk It will the display list of devices with memory storage. Find your disk, It should be in a Table(kinda). You have to locate it by its size. so look for 1TB(1000GB) In this Example its Disk 2, yours may differ.
type in: Select disk 2
Execute the rest one by one: CLEAN CREATE PARTITION PRIMARY SELECT PARTITION 1 FORMAT FS=FAT32 ASSIGN EXIT
Wait for one command to complete before running another
You should be left with a working FAT32 Device :P
Regardz Sinn3D
Oct 27, 2010 | Western Digital My Book Essential 1TB...
How do i partion my segate hard disk, it is 5oo GB
In order to partition a drive, you must use the partition manager. There is a command-line version of this application that is more consistent between the different Windows OS's so I'll instruct you in that.
First we need to be sure we are partitioning the correct drive. Open up My Computer and write down what drive letter your seagate external drive is (i.e. G).
Now let's start up disk partition manager. click on the Start button, and then click on "Run" type in "diskpart" (without the quotation marks) and press enter. This will open up a command prompt window with the heading "Microsoft DiskPart...".
Type in the following command: "list disk".
This will bring up a list of all of your disks currently recognized by the computer. Be sure the drive letter you wrote down earlier is on this list, also write down the drive number corresponding to your seagate external at this time. now go ahead and select this volume by typing "volume __" where __ corresponds to the drive letter of your seagate drive.
Now that we have everything set up we will create the partition.
type "create partition [size=_]" where _ is the size of the partition you want to add, in megabytes (MB).
If you encounter any trouble or want something more than a simple partition see the full instruction to use the diskpart utility here:
http://technet.microsoft.com/en-us/library/cc766465%28WS.10%29.aspx
Best of luck! and please rate my response
Jul 13, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Seagate freeagent drive
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
  1. Open Command Prompt.
  2. Type: diskpart
  3. At the DISKPART prompt, type: list volume
    Make note of the number of the basic volume you want to extend.
  4. At the DISKPART prompt, type: select volume n
    Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
  5. At the DISKPART prompt, type: extend [size=n] Extends the selected volume by size=n megabytes (MB).
Value Description list volume Displays a list of basic and dynamic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. extend Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space. If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
size=n The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
  • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  • To extend a basic volume, it must be formatted with the NTFS file system.
  • You can only extend a basic volume onto the same disk.
  • You can only extend a basic volume if it is followed by contiguous unallocated space.
Hope this helps!
Thanks
Mark
Jan 04, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Microsoft Windows XP Home Edition Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
