Me too, any info on repair cost or how to fix this problem?Me too, any info on repair cost or how to fix this problem?
AnonymousDec 30, 2007
Flash stopped working on SD550. Sometimes the message comes that the battery need to be replaced. But even with the freshly charged (old) battery, there is no flash.Flash stopped working on SD550. Sometimes the message comes that the battery need to be replaced. But even with the freshly charged (old) battery, there is no flash.
I set my camera back to the default settings but that did not solve my issue.My flash is not working.
i have tried every seetting to get the flash turned on, no luck. I even tried restoring to default, still no success. Please help. Without flash camera no Please email me.i have tried every seetting to get the flash turned on, no luck. I even tried restoring to default, still no success. Please help. Without flash camera no Please email me.
Olympus FE-130. The flash will not work despite being set to fire and the flash set mark displaying on the screen. I have tried out all the various modes for the falsh and none will allow the flash to fire. I have tried the camera at a number of different light levels but this does not work either.Olympus FE-130. The flash will not work despite being set to fire and the flash set mark displaying on the screen. I have tried out all the various modes for the falsh and none will allow the flash to fire. I have tried the camera at a number of different light levels but this does not work either.
When I try to change flash settings (pressing right arrow button) the camera says "Flash settings cannot be changed". How do I enable the flash settings???When I try to change flash settings (pressing right arrow button) the camera says "Flash settings cannot be changed". How do I enable the flash settings???
I have the same problem m flash just wouldn't work no matter what setting I put the camera on. It has justed stopped working all of a sudden. Please help me.I have the same problem m flash just wouldn't work no matter what setting I put the camera on. It has justed stopped working all of a sudden. Please help me.
Here is the solution: Flash cannot be used in burst mode! You must set the camera to single shot mode!
This really surprised me, since in my old Konica Minolta the burst mode did not prevent flash, it just took a single picture if the flash was activated or multiple pictures when the flash was disabled.
Check to make sure the flash up switch on the side of the flash (the switch you see where the wires go through when you remove the flash top) is not under the activation rod on the pivot, the pivot is not pushed in, or the activation rod is not broken off. The switch should close when the flash goes up and be open when it is down. A lot of times you see the top contact stuck under the activation rod. Also check the continuity of the two thin switch wires as sometimes they are borken inside by impact
look to see if the flash is turned on by conventional means such as through the setup or switch in the right position to activate the flash. This all depends on the make and model of the camera.
holding down the button on the fob activates it...signal lights should flash twice press the fob button twice and the lights should flash once , it is then disarmed
My Eco light was flashing fast ,and the drain pump was running continuasly.It turned out at the drip tray was full of water and micro switch add activated . i tipped the machine forward drain the water off the machine as be working fine since. PS dont know why drip add so much water in it, unless theres a leak. ???
First off make sure you dont have a faulty bulb check to see they are all good. you should know this by activating your turn signal if the indicator turns on but does not flash and you dont hear the clicking sound then you have a bad bulb. If all your bulbs are good then try changing out your flasher it may be faulty.
1. activate bluetooth on handset (phone) then immediately. 2. Press and hold mute switch on wep180 for 8 secs until led flashes blue. Release button only after you see the flashing blue led which indicates the WEP180 is active. 3.Enter the pin 0000 which is the default pin code on the WEP 180 and the handset should connect to your WEP 180 - I dont know how to get it to pair with the PS3.
presssing the SCROLL UP button toggles the flashlight function. if you carry the phone in your pocket, try activating the keyguard function (press "menu" then "*" ) this will prevent accidental activation of any key
I notice your message is from June 2008. Answer is easy. Activate your ericsson blue tooth feature. Remove facia of Tevion. On back panel is a button 'Pair'. Hold for a few seconds and the red security light will flash rapidly. Send activate message from phone to connext to radio. Enter code when requested 0000. Replace facia panel. Should be working now.
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Same probelm.
Flash quit working.
Had coolpix 5600 for one year.
Flash does not work any more.
how do I get the flash to work
no flash
i have the same problem as above, but I don't need to keep repeating the same issue, I need a solution to the problem.
thanks
beau
Same problem SD460 the pre flash fires but no flash for picture
flashes during the day
I have the same problem the flash on my camera wouldnt work. Please help.
