Question about DVD & Blu-Ray Players
Trutech TT320 DVD player remote code for GE remote 24921
I need to find a code that will work with this DVD player. I tried the search code feature on the remote (it technically has two search features. The on off button search and the channel up search) but to no avail. Is there another solution/does anyone have this code?
3 Suggested Answers
  • 247 Answers
SOURCE: disc error "playback feature may not be available on this disc"
the message you are getting is the machines waay of telling you that it can not read that disc. which means you will have to burn your discs in a different format. or your are using a type of disc it does not recognize.
Posted on Dec 26, 2008
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Posted on Apr 08, 2009
I have a DVD and VHS player in 1 and it was working well then all of a sudden the DVD player part just stopped playing. I stick in a disk and then it would read: disk error play back feature may not be available on this disk. And this disk is fine it plays in my daughters room in her 2 in 1 player. so What can I do? The VHS player works well. Help! I dont really want to buy a new one!
Posted on Jun 13, 2010
0 characters
1 Points
Hi, Lost the remote control to our trutech dvd player. What codes can we try with a uiversal remote? Tomas
just search in google type the brand. and model. find the code and you can find it
Jun 19, 2010 | TruTech TT320
Suddendly my dvd player --TruTech TT320 started saying "no disc" for all the DVDs I want to play. I tried 4 different discs. What can be done?
try to clean the lens with a lens cleaner.if the problem is still there, then your lens is should have it repaired.
May 31, 2009 | TruTech TT320
Display is stuck in Spanish.
on your remote for your dvd player hit your menu button then hit options it should have an option to change languages.
Nov 15, 2008 | TruTech TT320
I ahvde desparate to watch old movies rerecorded on dvds but it does not play on my DVD TT320 trutech dvd. I live in india and the same was presented to me bt cousin.Can i get any techinical help to make it wortk.
Oct 13, 2008 | TruTech TT320
Tru tech tt320 dvd player
When I install a disc my monitor indicates "loading" for a few minutes then "no disc" for several before the floating "dvd" appears. Meanwhile, on the remote, except for the "off/on" and "eject" buttons, no other button works. Please copy on your response. Thanks
Jun 08, 2008 | TruTech TT320
Trutech dvr model t650dr--ge remote codes?
hello..i'm afraid that you must purchase an original remote..try any local dealer or search the web google..there you search accessories for your truetech dvd and see what happens...good luck...Ron
Mar 07, 2008 | DVD & Blu-Ray Players
Unversal remote code
Not this time around...sorry...accordianman
Feb 25, 2008 | TruTech TT320
Trutech TT320
"Hide" the remote and try to operate the unit using the front panel controls. Does this work? Then the problem is the remote...accordianman
Feb 18, 2008 | TruTech TT320
My remote is trashed....
Wish I could help, but I have the same problem. Thought it was bad battery contact, so popped the back off. Cleaned contacts, no difference. What I don't know is if the remote is bad or the receiver end in the player. No way to tell that I can figure.
Dec 26, 2007 | TruTech TT320
If the product does not work because the remote is obviously faulty the dvd player is a piece of sh......t! what are you going to do about it trutech? no universl remote that I have found works..
Dec 19, 2007 | TruTech TT320
DVD & Blu-Ray Players Logo
441 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
