Question about Nikon D40x Digital Camera
Yellow tint on images
I just got my Nikon D40x and the images are coming up with a yellow tint across them. I tried to shoot indoors and outdoors and even see if they would appear different when i downloaded them. They still have the yellow tint on them. Is there a setting you can change to adjust this problem?
  • Anonymous Jan 18, 2009
    What could it be is not enough to me .I do not know how to fix it.
When i go to the white balance option on the menu, it says "This option is not available with current setting. " I haven't set anything different from the factory settings. Could there be a reason it's not giving me this option?
Posted on Dec 27, 2007
  • 667 Answers
There should be a setting for white balance to be in auto. Check the shooting menu options
Posted on Dec 26, 2007
Nikon d90 lcd screen yellow tint i want how to change
Switch off ambient light sensor that should do it
Oct 19, 2012 | Nikon DSLR D90 Digital Camera
I have a Nikon Coolpix L110 and the pictures have a yellow tint when taken inside. I've noticed the yellow tint varies when I point the camera to different areas in the room. I've never had an...
You have a white balance issue. Somewhere in the menu system is a command to alter the white balance - for indoor shooting by artificial light (i.e. light bulbs) it should be set to 'tungsten'. Using flash would overcome this, but the pictures would look very harsh and unnatural.
Jun 14, 2017 | Nikon Coolpix L110 Digital Camera
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    Aug 10, 2010 | Nikon D40x Digital Camera
    Overexposure in AV mode
    check your EV settings.. might have set it high on +7
    Nov 11, 2008 | Nikon D40x Digital Camera
    Shutter Speed too slow on indoor sports for Nikon D60
    Maybe. Assuming you can't add more light, you can either increase the ISO and/or open up the aperture. Try going to A (Aperture) mode and opening up the lens all the way. This will give you the fastest shutter speed possible under the conditions. That may or may not be fast enough.
    Nov 02, 2008 | Nikon D40x Digital Camera
    Yellow/green tint indoor photo using auto portrait mode
    Hi - You can download the Nikon D80 Guide to Digital Photography manual by clicking the link underlined in blue below:
    Nikon d80
    Firstly see page 58:
    Try setting the white balance to fluorescent an compare. Also you could set your own white balance preset by shooting a white card as per page 59. Lastly you can play with the "tone adjustment" on page 80.
    Let us know how you get on!
    Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
    Informatica
    Sep 11, 2008 | Nikon D80 Digital Camera with 18-135mm...
    Incorrect metering
    it may be a problem with the camera, but you should be using the manual modes....they are much more accurate. if you are worried about it being a defect issue, then send it in.....
    I have one also, and have found it to be a bit slow on the metering side on the pre-programed modes.....
    May 17, 2008 | Nikon D40x Digital Camera
    LCD show purple or violet cast on white areas when using auto mode
    Have you tried viewing the photos on a computer or printing them? There should also be parts of the menu/setting displays that would be white. The text on the image info should be in white.
    If you are getting white, it would suggest your whitebalance isn't set correctly. If everything has a purple tint to it, check your LCD display settings, otherwise it may be the screen is failing.
    Dec 31, 2007 | Nikon D40x Digital Camera
    D40X raw format reading error
    This does not seem to be a problem with the camera, but a problem with the computer software.
    Dec 06, 2007 | Nikon D40x Digital Camera
    Photos coming out with too much yellow
    You're shooting under incandescent light, and the camera doesn't manage to set the white balance entirely automatically. You can try to explicitly set the white balance to incandescent, or you may be able to create a custom white balance (I'm not sure whether Nikon bodies offer that feature), or you can adjust the white balance during processing (in which case it's better to shoot raw).
    Sep 14, 2005 | Nikon D70 Digital Camera
    Nikon D40x Digital Camera Logo
    195 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
