Question about SanDisk Sansa e270 MP3 Player
E270 still won't turn on..hold button is not on...HELP
The hold button is not on, tried switching it in both positions, but any time i try to turn on the device, it still says key locked, system shutdown.
Defective maybe?
  • Anonymous Dec 30, 2007
    I tried the HOLD switch both sides and the key locked comes up. won't power on.
  • Anonymous Oct 29, 2008
    same thing for me
I bough the product last december 06
it just stop working
that the worst MP3 I EVER PURCHASED
Posted on Nov 01, 2008
It happened to me 2...it cut off right in the middleof a song and wont turn back on. i just held the power button till it came back on(about alf a freakin minute) if u try this it might work. gl ;)
Posted on Feb 12, 2008
    Sergeant:
    Champion:
  • 209 Answers
..Try to connect it to your computer and see if you can access the files, if that doesn't solve it bring it back, they'll hopefully give you a new one or fix it.
Posted on Dec 25, 2007
  • Simon Zwaan
    Simon Zwaan Jan 23, 2008
    Please rate, or respond with more details.
My keyless remote stop working & i tryed the step and it only work once. please help
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Mar 26, 2010 | 2001 Mercedes-Benz M-Class
How to reset the sansa e270
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 29, 2009 | Audio Players & Recorders
Screen is off. It's frozen.
Holding the power button for 20 seconds should reset it.  Otherwise, there are many solutions on the support page here.
May 27, 2009 | SanDisk Sansa e270 MP3 Player
My e270 will not turn on
In the settings section of the menu you can select a different USB mode try that and then try the reset which is holding the power button down for at least 30 seconds
Mar 25, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 freezes when USB cable disconnected
Reformat the whole thing with Rockbox. That's the whole point with buying the Sansa, as far as I understand.
Jul 12, 2008 | SanDisk Sansa e270 MP3 Player
Entering recovery mode is not possible
Disengage the lock switch, then try this: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 03, 2008 | SanDisk Sansa e270 MP3 Player
Problem starting
Get the Sansa Recovery Tool from the sandisk website
Jun 28, 2008 | SanDisk Sansa e270 MP3 Player
Refurb Sansa e270
Hold the power button for up to 30 seconds to "reset" the device.
Best of Luck.
Oct 31, 2007 | SanDisk Sansa e270 MP3 Player
Wont go past starting screen PLEASE HELP!!!!!
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. FYI, if you are using music from Limewire or other P2P sites, they are to blame. They are usually poorly encoded and cause the device to freak out. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e270 MP3 Player
Refresh database SansaDisk e270
Sorry, no habla espanol. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
