Question about Hitachi 50UX57B 50" Rear Projection Television
Pin cushioning or barreling.
I have a hitachi 50UX53K projection tv.Which is having a pin cushioning picture.The service tech just replaced the PNP module before this started.
  • Kristian Watkins
    Kristian Watkins Mar 05, 2008
    I just bought a 53" samsung and have a pincushion problem All I need to know is how to realign the glass, (I think)
    President:
  • 4,402 Answers
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 07, 2008
I have a Hitachi Ultravision TV Model #50ux53k v7h002332. The remote is working and also changed the Batteries. The Tv is not reacting to the remote like it should. It randomly will not turn on or off and...
if you have to hold the remote very close it is likely a bad remote receiver in the front control panel; the only other reason would be a dirty lens there or at the top of the remote.
Let me know if all manual front buttons work normal.
SD TECH
Apr 28, 2011 | Hitachi Televison & Video
The background color on the tv is starting to bow in different directions. the original picture looks good but it looks like there is a shadow below it that is a different clor and wavy.
Hi, it's look like you have a convergence module defect and pin cushion problem;/after replaced the module the tv set will need to be adlust.....
that as to be done by a tech
hope that gives you an idea
have a nice day...
Apr 13, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi 50ux53k
Good Day, egipson;
When the CRT's Coolant (fluid) get onto PCB's, one can clean the boards with acetone. BUT YOU MUST MAKE SURE ALL POWER IS REMOVED FROM TV. SAFETY FIRST.
Good Luck, big IRISH. PS after cleaning [place heavy plastic over effected areas.
Aug 26, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Picture pincushion
converenge amp ic bad or loose connection
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Hitachi 50UX57B 50" Rear Projection...
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 43fdx20b blurred Picture
Yes this is a normal diagnoise. Just about every Tube type projection TV set ever made will one day need these IC's replaced. They are not really that hard to replace but you would need to know how to solder and unsolder on printed circuit boards, know the procedture, and then have a service manual handy to adjust the convergence after yoou replaced the IC's. If the tech works on alot of these types of TV sets's, most likely they could adjust them without having a service manua handy. This repair done by a pro should run you anywhere from 250 on up to 400 bucks depending on who does the repair and where. Good Luck
Mar 31, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
104 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
