Need Location of Part # on right front circuit board (if looking at it from the back of the tv) I just finished soldering in new IC heat-sinks on this board and set on top of TV and a cat jumped on it knocked of the board and broke a corner off. So I need a complete new board with everything already on it.
Comments:
Oct 09, 2009
- The left front corner by Heat sink 3" down side and 1 1/2" of front Diagonal break
I think you will find the board for this set is not available or if it is not at a reasonable price.
Usually if a fairly small part of the board is broken off it can be repaired-----I can tell you what is involved in this type of repair if you give me some idea of how bad the damage is.
I have repaired circuit boards broken in half---once fixed they are not pretty but will work perfectly.
let me know if I can help you--I am here to help.
SD TECH
Comments:
Oct 09, 2009
- OK, FIRST thank you for your kind words and vote.
Here is how I would fix this if i had it---super glue the broken part back--look at all the foil paths--they are copper with a green coating on them---once the board is intact---you remove the green coating either with a sharp object or I use a pen with a fiberglass wand--once all the damaged foil paths are exposed--you flow solder along them on either side of the break--then you solder wire--I use wire have here---you bridge the breaks by soldering wire across them---
Once the wire is there--it replaces the copper foil paths----I just did this for someone here who tried to replace a convergence chip and damaged (destroyed) several foil paths to the chip(15).
Any good tech can do this---if I was able to see a photo of the damage I might be able to offer advice--it is not permitted here for me to have or give you my email address---9 out of 10 times physical damage of this kind can be repaired.
etower.766@netzero.net--------------------
regards, SD TECH
Oct 09, 2009
- opps! did not mean to give my address.... disregard
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Great gave me some hope that it is not a total loss.
" - 6forhim
Popular Solutions for Pioneer SD-533HD5 53 in. Rear
picture disappears while TV is on. When TV is turned off for a while, it turns back on, but only...
(More)
picture disappears while TV is on. When TV is turned off for a while, it turns back on, but only runs for about 5 minutes and then turns off again.
my protective screen is cracked on my pioneer sd533hd how can i remove it I need to know how to...
(More)
my protective screen is cracked on my pioneer sd533hd how can i remove it I need to know how to remove it and were i can by a replacement
