Microsoft Windows XP Professional Logo
Posted on Oct 09, 2009
I can not install operating system(error code 4 and code 7)
Anonymous
Level 1:
Problem Solver:
  • Contributor 31 Answers
  • Posted on Oct 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
31
Questions
0
Helped
12886
Points
82
Error code 4 -- try resetting the ram chips
error code 7 -- Your error is probably because there is a problem reading the CD. Make sure your CD is clean, and try a cleaning the laser lens in the CD drive with a laser lens cleaning CD.
2answers
My toshiba laptop displays an expected error occured. Error Code 0xc0000034 during booting window
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop.
The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file.
You can try the following steps and can try to resolve this issue:
1. Boot into the Windows Recovery Environment (WinRE)
2. Launch the Command Prompt.
3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd".
4. Press Enter and follow the on-screen instructions.
Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
My epson 600 shows an error code 0x 9D and when turn the printer off and on the error reapperas
Epson Printer Error Code 0XE8 is an annoying problem for printer users of Epson. This error message occurs mostly due to the compromised operating system or can arise due to the corrupt software on your computer.
Reasons that cause Epson Printer Error Code 0XE8 because of Dry ink, paper stock, and paper jam is another reason. Substantial damage to the device and broken system shutdown can also cause Epson error 0xe8. If the system is newly recovered from any malicious virus or malware attack then the printer may show the error code. Unsuitable software and applications present in the system and incomplete installation or un-installation of applications. here is 5 Solution:-
1. Standard Update.
2. Automated Method.
3. Printer Driver Update.
4. Using the Troubleshooter Tool.
5. Turn On the Printer Online Mode.
Blog - Epson Printer Error Code 0xe8
Thanks for Reading
Error code 2000-0151
Give some more information, like have you installed any operating system before, or made changes with operating system, which operating system this come with?
1helpful
2answers
Windows update failure (KB982670)
Believed me you have to reinstall your operating system. I encountered that problem too. I uninstall and re-installed .NET, update windows service packs nothing happened until I reformat the hard drive and install the operating system again.
remember format the hard drive first then install the operating system (backup your data first)
Some updates were not installed, code 800B010B
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
2answers
When I start the laptop (HP HDX 16) I get this messege: Boot device not found Error codes Hard Disk-(3F0) pleas install an operating system on your hard disk. F2 system diagnostic. but it does not install...
The Windows edition listed in BIOS (Vista) is referring to the operating system that came with the computer. BIOS's System Diagnostics will always say the OS is Vista, because that is the original OS that HP put on the system. BIOS itself, however, cannot detect an operating system on the new Hard Drive because there is no operating system. In order to get an operating system, you have a couple options:
Depending on the terms and length of your warranty, you may be able to get HP to reinstall the operating system back onto the new Hard Drive. The amount you would pay depends on the warranty. Many warranties, however, become void when you change physical components in the computer (especially with laptops). If this is the case, you will have to try the next option.
You can buy a retail copy of Windows either online or from an electronics store. The price will depend on what edition you purchase, but it will probably cost you at least $100 US.
You can install a Linux operating system on your Hard Drive. If you've never heard of Linux, it is an operating system based on much of the same code as Mac operating systems, but has a more "Windows-like" feel to it. Linux operating systems are NOT the same as windows, and some programs that work in Windows will not work in Linux; you would need to find the Linux counterpart for these programs. One of the best things about Linux operating systems are that they are absolutely free to download, install and use. A very popular and stable Linux operating system is Ubuntu, which can be found at: http://www.ubuntu.com/
4helpful
2answers
Installing the adobe photosop there is a messege that appear error number 0x80040303
what operating system are you using the error code implies that the driver for the software is not compatiable with your os
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
1.Restart your computer if you haven't done so already.
There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
Undo the change, restart your PC, and then check again for the Code 28 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
