Question about Panasonic Vacuums
IT DOES NOT WORK AT ALL
It was working ok, but while I was using it, it stoped. I open the dust container which was full. I empty it, than I plug it in again, but still not working. What should I do next? It's a Panasonic MC-E7303 1600W
    Sniper:
  • 84 Answers
Hi there. In Panasonic vacuums, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again.
Posted on Oct 10, 2009
Testimonial: "I did what he sugested, and after it...the vacum work again. Thank you very much."
  • 3 Answers
Try letting unit cool. If container was full it may have overheated. Also should clean filters while cooling down. If this does not work then its time for the shop. Most likely the cord.
Posted on Oct 09, 2009
Testimonial: "It was the overflote. I let the vacum to cool down and then I tryed again, and it work. I didn't need to go shopping. Great!!! Thanks."
Is there a reset? Emptied container, hit power on b4 container replaced, now power button lights, no power
yes the dust cups need to be in place b4 the motor will run on a dyson vac , id look to see if you may have bent or broken the little white plastic switch under the dust cup
Dec 07, 2016 | Dyson Vacuums
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 18, 2016 | Shark Vacuums
I am going to start a small business, which i am going to clean bins. so i am going to use water, so i would like to know where can i get rid of the contaminated water that i am going to use once i have...
I would buy or find a huge water tank and drain the contents into it once its half full por wood shavings or an absorber in to dry it out,or if you filter the water you can use the water for plants,shrubs..
Oct 29, 2013 | Dyson DC27 Total Clean Dust Bin Container...
Can't find booklet. Need to empty full container. Thanks.
Remove the dust cup by pressing the button on the top of the cup.
Pull cup out.
Place over garbage can or into a bag and press the red button.
Shake a bit until cup is empty.
Return cup to holder and secure it by pressing in until it clicks.
The manual is located at the following link. It's downloadable and printable. Emptying instructions are on page 8.
http://dl.owneriq.net/4/4d79dca8-65d8-4c46-a58a-a2fef1f89635.pdf
Mar 02, 2011 | Dyson DC14 All floors Bagless Upright...
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
My bissell vacuum has no suction. the power works and the brush turns but I have no suction. what should I do?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Sep 25, 2010 | Vacuums
How do you empty the dust container?
Actually Fixya does have the owners manual for your particular model downloaded to their site. Please see page 5 of the instruction manual that will explain how you can empty the dust container. Also instructions on basic maintenance in terms of the filter replacement, and belt changing. This is a very useful booklet to have.
I hope that this helps you;
http://www.fixya.com/support/p12392-eureka_2971av_ez_kleen_bagless_upright/manual-3962
Chris Jones
GoVacuum
Mar 23, 2010 | Eureka 2971AV EZ Kleen Bagless Upright...
Shuts off when suction starts
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Oct 17, 2009 | Vacuums
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Vacuums Logo
489 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Archie Ferrarini
Archie Ferrarini
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
