Question about Radio Communications
No connector I Can not find a connector that will fit a 400 type Coax to a CB radio.
    Champion:
  • 204 Answers
MCM electronics may have an adaptor..Google their name to get the website
Posted on Feb 05, 2008
Wilson roof mount coax is broken at radio connector end
I'm going to assume you've got a PL-259 connector on the end of the coax cable - they look like this:
They are designed to screw onto the radio's RF / Antenna jack. The end shown is standard, the other end - that the cable enters, requires an insert that matches the coaxial cable outside diameter.
There are two versions of the connector; solder-less and soldered. The best connection is provided by the soldered type. It is superior both electrically and mechanically to to the solder-less version. If you lack soldering skills, patience and / or the tools and supplies to solder the connector, the solder-less version will be the way to go.
There are two types of solder-less types, a crimp and non-crimp type. They look like these:
The "Non-crimp" solderless PL-259 from Radio Shack - about $6.
A crimp type PL-259 connector - $2 and up at various radio & electronics stores.
Since this end of the antenna is at the radio and presumable protected from the elements, it may prove to work very well for you. Each of these connectors requires knowing the type cable (RG-58 and RG-8 are very popular types - but there are many other 50 ohm coax cables) or outside diameter and selecting the one that fits correctly, along with a crimping tool (and dies) for this particular connector size. You may get by with a standard pair of pliers, but the connection is not as good as would be obtained with the crimp tool. Generally, you would provide a crimp around the ferrule at the cable end for the braided conductor and another at the very tip of the connector for center conductor.
Each connector will include very specific cable preparation steps for the removal of insulating jacket, braid and dielectric material to provide proper fit of the connector to the cable. If it were a "standard", I would have included it.
Check this link for Youtube video the show how to install the various types of PL-259 connectors on cables.
I hope this helps & good luck!
Jun 05, 2012 | Radio Communications
Can't talk long distance seems I can only talk for a hundred yards and then I can't hear other drivers
  • Hi, I can help.
  • The most important part of a CB set up is the antenna and the coax/connectors being used. Make sure your antenna is a good one. If you want a suggestion on a good one leave a comment with your budget and weather your using a mobile/base set up. Make sure your connection is goo. Check the PL259 and make sure the braids have not split off for inside. Soldier a new one on if necessary.
  • I will give you some instructions to peak your CB and adjust the receive. Make sure the CB ha no power and use a plastic screwdriver inside your radio.
  1. Pull the bottom cover off of your radio.
  2. Put a watt/power/SWR meter inline.
  3. VR1 is your receive gain, adjust that to pick up from farther away. Note white noise can occur along with this as you will be sensitizing the front end.
  4. Adjust VR4 for 100% modulation (swing)
  5. Right by the final is a can with some glue on it. Scrape the glue off and turn that ferrite out until your power output is 4 watts RMS (not bird)
  6. Your Cobra 29 is now peaked and tuned as much as possible without using a Oscilloscope. And doing this this way will not require a re-alignment afterward.
  • Don't touch any other pots in the radio.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 19, 2011 | Cobra 29 LTD CB Radio
Hooked up cb, blows fuse when the mic is keyed
when mic is pressed transmitter is engaged. First is the Fuse the proper fuse? Could be an antenna-coax problem. Get a dummy load and hook up to your CB and try it again. If it doesn't blow the fuse, the problem is indeed in your coax antenna system. another way to test your antenna coax is to disconnect it from the radio, take a multimeter, set it to ohms 200 ohm scale, put one lead on the center pin of the coax and the other on the outside of the connector on the coax.if it shows anything at all, you have a short and that will not work. It needs to not read anything. To be sure the antenna system is ok other than swr you can also check the coax an antenna for continuity. one lead of meter on the coax center pin then other on the antenna. should get a reading, a low value. again on the outside of the coax at the connector and at the antenna side on the outside of the coax connector. should be a low reading. but you cannot have a reading from the center of the coax to the outside of the coax. disconnect the coax at the antenna and measure from center to outside at the coax if the previous reading showed a value.If you see a value on the meter, any value, your coax has a short. not good. most likely at the coax connector. redo the connector. It is possible that the coax got compromised somehow and got smashed to the point the outside coax meets the inside and touches.
Now the other possibily your fuse blows, kis because the final output transistor is bad. So if you hook up a dummy load to your radio and the fuse still blows, then the final transistor is bad. This is probably due to a bad coax-antenna system. So before you replace any parts check the coax-antenna system first or you will have the same problem and burn out another transistor in the final. If none of this helps then just get another radio or have a god buddy look at it that knows about radios. Trade him another radio or something to fix it.
Feb 08, 2011 | Radio Communications
Hello, I need help with a cb problem. My radio isn't reaching or receiving any thing farther than 100 feet. I just rewired it directly to the battery and I have a fire stick antennae.
Having that short a range would give me the indication that there is a disconnect in the antenna system. Here's a couple of clues: Is the connector on the back of the radio connected to the coaxial cable?
If it is not factory installed connector, is it possible that the solder job on that connector was bad? If the cable is old, it could have a crack in the coax.
Is it the RIGHT kind of coax? It should be an RG-8, and RG-58, or a variation of those types of cable. It would likely be marked with "50 Ohm" somewhere along it's length.
Is the connection at the antenna solid? A firestick antenna for CB looks like this:
You must make a good connection at the base of the antenna from the center coax conductor that does NOT short it to ground, and the ground conductor should attach to the antenna mount frame.
With your symptoms, it is very likely that either the center conductor has worked loose, has become unsoldered from the terminal lug, or your coax has come unsoldered from the center pin. All of these things would really honk up your SWR, or Standing Wave Ratio, which is sort of like a string on a guitar that is tuned to a specific frequency for a specific note. The center freq of the CB band is 27.155 Mhz, so you would typically "tune" your antenna for that to be the lowest. A firestick KW is not tunable, so that should not be an issue. Look to your coax at both ends, and the coax itself to find your problem. If you have a simple ohm meter it would help to locate the short circuit. Good luck, write back if you need some assistance in further troubleshooting.
Apr 02, 2010 | Radio Communications
With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Mar 26, 2009 | Uniden Radio Communications
Coax seems shorted
OK TAKE THE COAX OFF THE CB AND CHECK THE OUT SIDE AND INSIDE FOR CONTINUITY 0 OHMS IT IT DOES NOT SHOW 0 OHMS THE COAX IS GOOD. YOU ARE READING THE CIRCUIT INSID -E THE RADIO AND IS NORMAL.
Mar 13, 2009 | Cobra 29 LTD CB Radio
Coax ends
Hello kewball,
You can buy the PL-259 connector at radio shack (Here is a link to the instruction on how to put a PL-259 connector back on):
http://www.stu-offroad.com/misc/rfconn.htm
I hope this helps
Thank you,
Shuttle83
Nov 04, 2008 | Cobra 19 DX IV CB Radio
Signal meter
The signal meter would go into the antenna path something like this:
Oct 06, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
