Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
No power I took TV off of wall mount. When I put it back on, no power. Tried different outlets, but no better.
  • 138 Answers
Check connector between Logic & PSU 2nd pin from Left (Vs_ON) for DC volts.
If Voltage is 0 then problem is with Logic or SSB.
If Voltage is 3.1 VDC then problem is with PSU or other PCB's on Panel.
On startup Logic checks for errors and also polls the SSB for Errors. If Errors found then Logic will not send High to PSU.
To confirm if SSB or Logic is at fault then disconnect and remove SSB.
Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Posted on Aug 20, 2008
Can I buy screws to fix base onto my umc tv
Yes The screws that you took off the back of the tv mount on wall brackects mounted on the back of your TV should be the same size
6mm
Oct 23, 2014 | Televison & Video
Plasma TV-power light does not come on
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
Tv problem help
With the plug from the t.V. unplugged from the wall outlet, remove the tv cover. Follow the power cord to the power supply's printed circuit board. Look to see if there are any damaged, bulging or burnt out (exploded) capacitors. If there are, that's the source of the problem.
Be fore warned, even though the power cord to the tv has been disconnected from the wall outlet, good capacitors still hold (store) hi-voltages that can shock & even kill you; so don't touch them unless you know how to properly discharge a capacitor. Don't underestimate the power that these components store even though they are very small.
See this video 1st : http://youtu.be/AvlNKZ8GzEg
and this one as well: http://youtu.be/B41PeSDF_dk
Warmest regards
Mar 11, 2014 | Mitsubishi WD-60735 Projection Television
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
The screen goes complete blank with sound still on. It takes to shut TV off and power it on right away to get picture back-though the intervals getting shorter down the road . MY Screen goes black and I...
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Jun 01, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
How can I put the base back on my tv Sony Bravia KDL40S2000
Lay the TV face down on a flat surface covered with a cloth. Back out all the screws holding the base stand. Hold the back and front against the base shank while tightening all the screws through the base. Make sure they are tight.
Feb 25, 2009 | Samsung LN-S2641D 26 in. LCD HDTV
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
