Question about Samsung SMH7178STD Microwave Oven
Samsung Microwave. I put the time on 25 minutes and cut the microwave on and came back and have no power.
  • Samsung Master
  • 9,098 Answers
Chances are the thermal cutout / thermal fuse or thermostat on or above the magnetron has failed.
Hopefully it did its job and protected the magnetron from destructive overheating...
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 20, 2008
I replaced the door switches on my microwave. Now, when I re-attach the control panel, I hear a clicking noise and the power cuts out.
The panel is shorting to metal parts. Was there any insulating materials you didn't put back on? You might try some black electrical tape applied to the edge of the control panel.
Jan 04, 2017 | Samsung Microwave Ovens
Microwave would cut off after a few minutes and then turn back on but now there is no power at all.
There are few reasons for this fault, but the main is that you need to open your microwave oven and first check the Fan which is connected at the back which cools the magnetron.
If this fan fails thus results in magnetron being overheated and the thermal cutoff gets open circiut and shuts down whole power of your microwave oven.
Check your fan motor test it straight with direct power
Also check the thermal cutoff.
Let me know after you have done those checkups
Regards
Ashwin
May 22, 2015 | Magic Chef MCD1611ST Microwave Oven
How do I enter a time of less than 1 minute? Bought a brand new Oster Microwave model OGZJ1104. I cannot figure out how to heat up a cup of coffee for example - for 30 seconds. The user manual has
Usually a quick start button along with dial to scroll down from one minute.check if any buttons are push click to see if they extend away from fascia once pressed or try select one minute then use main dial anti clockwise to reduce time.hope this helps.
Feb 01, 2015 | Oster Microwave Ovens
The microwave keeps cutting out after 2 to 3 minutes and you have to wait 2 minutes for it to come back on again.
Check the internal temperature switches. They are small, round, and metallic in appearance with 2 spade connectors.
Jan 18, 2015 | Microwave Ovens
I put a mug of water in the microwave, left the room. Came back, and the room was filled with a burning electrical/plastic smell, no visible smoke. Now, the microwave completely powers off after 1 second...
Since there was no smoke, it's not a transformer. It's most likely a high voltage diode or magnetron. The magnetron would be over heating and opening a thermal cut out mounted to or near it.
Oct 19, 2013 | Samsung SMH9187ST Microwave Oven
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
Microwave oven no. NN-A514 cuts out when cooking
I had that issue and I opened the unit and there was a fuse near where the power went in. Went to the small local hardware store and they ordered it. It was well under $5 (can't remember) but it still works over 10 years later.
If the fuse blew again I would have trashed the unit.
Dec 21, 2017 | Panasonic Microwave Ovens
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Killed the microwave by running it empty for 30 minutes.
YES THERE IS AN INTERNAL FUSE OR DIODE YOU CAN CHANGE, BUT YOU SHOULD BE CAREFUL AN LET A PRO DO IT, YOU JUST DON'T WANT TO GET ZZZAPPPP WITH THE CAPACITOR THAT STORAGES HIGH VOLTAGE INSIDE TO PROVIDE THE MICRO WITH POWER, IT MAY SEEM LIKE A LIL UNIT BUT IT CAN HURT YOU IF YOU DONT DE-ACTIVATE IT RIGHT, NOT SURE IF THE DIODE WOULD BRING IT BACK BUT CHECK WITH A SERVICE MAN, BEFORE DOING ANYTHING I WOULD!
May 28, 2009 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
137 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
