Question about LG LFD790 System
LG LFD790 installed with cable
I can get the LG LFD790 to work with DVD's, but not with my cable box and plazma. I have a comcast dvr cable receiver connected to my Samsung plazma via the hdmi cable. How do I get this so I can use the LG LFD790 home theater system with both dvd's and cable tv?
TV CONTROLLS LFD790
Posted on Jun 18, 2008
If there is an input on the back of your cable reciever get a fiber optics cable and put it in to your theater system and into the box then select "ez/optical" and your tv should come through, or you can connect the fiber optics cable on the back of your tv into the system and keep the tv volume off
Posted on Feb 24, 2008
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Unable to receive signal through my Comcast box, but signal is fine from the cable???
It turns out that the DVR has to be on channel 3, and the channels are controlled by the cable box! I somehow had missed that part. With the DVR on channel 3 and the channel being changed through the cable box it is very awkward to try and do any recording unless it happens to be what you are watching, so I have basically given up the whole idea and am planning to return my cable box an go back to basic.
Oct 06, 2009 | Panasonic DMR-EH50 DVD Recorder
LG LFD790: surrond sound only DVD mode?
go to the DVD screen and hit home button, scrool to the "EZ" icon and it will say AUX or OPTICAL. Chose OPTICAL and swich back to cable and you should have sound. This will work, and no the manuel does not tell you this and most techs have no idea. Best luck
Aug 28, 2009 | LG LFD790 System
Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Apr 03, 2009 | Philips HTS3544/37 Theater System
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
DVD connection
The standard connections are yellow=video, white and red are left and right stereo audio. The easiest is straight to the TV
Jan 22, 2008 | Televison & Video
Record DVDs frrom Cable box DVR
Buy a recorder that records both +/-R and double layer disks.
I haven't seen a Comcast dvr but you should connect it to the svideo out port of the dvr to the svideo in of the recorder and the audio out to the audio in. If the Comcast doesn't have svideo use the video ports instead
Dec 20, 2007 | Cyberhome DVD Recorder - DVR1600
LG LFD790 System Logo
440 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
