Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
Usb i have delete the partetion of my 1gb usb what shall i do
  • Anonymous Jan 09, 2008
    i have delete the partition of my 1gb usb when i connect it to my computer it show no disk in derive and in usb properties it shows disk volume (0)
    free space (0)
    used space(0)
    give solution
  • hell boy Jan 29, 2008
    the answer does not work when i conect my usb the (H) derive which is usb derive show no disk in derive
    and when i check the properties of my usb it shows disk volume(0) and free space (0) what to do
  • 1,226 Answers
Connect you usb
click start to control panel
switch to classic view
double click " administrative tools"
double click " computer management"
under the storage
Click "disk management"
under volume
click your usb drive
and below you can "right click" and partition youtr usb or can format it.
note; all files on it was destroyed.
Posted on Dec 26, 2007
  • Emelio Navaja
    Emelio Navaja Jan 29, 2008
    you should partition that again in the disk management. if ever did not work, i probably assume that the USB is damage. that is why my solution is not working with you.
    U try my solution but sad to say that not solve the problem but that is the correct solution on that matter. that is not my problem im just only helping the problem to be solved, its maybe that is not the correct solution for you. that is why u give me inappropriate solution. You; Do you know the solution of your problem that's why you rate my solution nothing at all. I guess you don't know that's why you ask solution.
    So therefore: i conclude that USB drive was destroy after you intentionally delete the partition because that is the only solution for that matter.
    hope you understand. Have a nice day. melnavz
How i can clean my hardrive in my hard drive there is 2 gb left because of that my computer doesnt work fast. what i have to?
hey... first run disk cleanup... then start>run> type %temp%... delete all files in the folder... then for ultimate speed, run the disk defragmenter....
Apr 19, 2010 | MSI VR420 Notebook
Showing write protection problem
move the small jack present on the side of your memory card,it is for write protection enble, disable.
Mar 16, 2010 | Kingston 1GB Secure Digital Memory Card
Sandisk microsd 1gb help
Try doing a complete formatting again.
If that does not work, delete partition and try doing formatting with a tool like the one below.
If the software below does not fix the problem, then replace the card.
Sd Card Partition Software Downloads
Partition recovery software
Free download corrupt hard disk partition data repair software
Jul 15, 2009 | SanDisk 1GB microSD Memory Card
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Verbatim 1gb flash drive privacy zone lost space
try this link.
Aug 13, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
I have an Averatec model#3150p pc notebook.It has a 3 port usb hub but only 1 port works. i.e.:When I plug a device into the 2nd or 3rd port I get error message saying the device has a problem.(unknown...
Dear Friend..
Go to Control Panel=>System => Harware=> Device Manager. Under the "Universal Serial Bus Controllers" delete all USB root hubs & controllers/ ports & then Action=> San for hardware changes That shall freshly install the USB ports on your system & shall work.
Best of Luck..
Jul 10, 2008 | Computers & Internet
Harddisk space problem
you can also format fat ................then partetion perporly
1st you cd setup Os cd then setup BIOS.......
delete all patetion.....& creating new patetion.......
same &equal 60 gb do partetion.......
then setup your Os ......
May 05, 2008 | Computers & Internet
Kingston usb 1GB
Have not encountered a problem like this before, but you can try booting from your Windows CD if you have Windows... While your USB is inserted in the USB port. After entering the setup continue until you find your partitions where your drives is listed, you will notice your USB Drive will also be listed there. Select your USB Drive, and simply Delete it and recreate the drive. After that, just reboot your PC, and do not continue the windows setup.... Boot up Normally, and see if it works.
Hope it helps
May 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
About 1 gb usb
hey i had this issue too....
but myne was a little different on a 64MB card it showed 33GB but it was a virus..!!
what i did was i plugged it on a mac and formatted it and came back to life a a new drive !!
I think this helped !! if no mac then try the dos !!
like this : Your Driver Letter=G:
take run type cmd
in the dos window type " Format G: /X /FS:fat32
then type the current name of the volume(NAME or try Removable Disc)
and press ENTER
after the format type EXIT
and there u have ur drive back !!
Jan 09, 2008 | Kingston (SDCZ2-512-A10-KT)...
Deleting pictures
Have you already tried onnect the mp3 to the usb port and using my computer to see the player.
Jan 03, 2008 | SanDisk Sansa c140 MP3 Player
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
51 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
