Led display the screen image appears to be either concave or convex rather than flat. I think it is concave.
  • dewmamma Dec 25, 2007
    Adjust it to what? We have tried everything we can think of in the adjustments.
    Scholar:
  • 103 Answers
Go into the monitor menu settings and adjust it.
Posted on Dec 25, 2007
I don't know what concave means
The curve of a lens is either convex or concave, that causes light to be focused depending on the direction of the curve.
So to answer your question, concave is just a bulging 'out' shape.
Feb 19, 2014 | Concave Lumbar Support-A6000
Compaq Presario V4000 laptop lower volume button (just to the right of the power on/off button) stays depressed. The button is concave now instead of convex. What to do?
Does the machine have regular keys (that remove) or a "blister switch" type key pad? Have you tried to use compressed air to remove any obstruction? OR try to pry the key, very gently, up? A LITTLE silicon spray? You may have to remove the keyboard. If you use the Tray Notification Area Sound Icon to increase volume what happens?
Dec 11, 2012 | Compaq Presario V4000 Notebook PC
How do convex polygons differ from non-convex polygons?
A convex polygon is one with each of its interior angles less than 180 degrees and every line segment between any of its two vertices remains inside or on the boundary of the polygon.
150px-pentagon.svg.pngExample of a convex polygon (WIKIPEDIA)
A concave polygon will always possess an interior angle with a measure that is greater than 180 degrees.
150px-simple_polygon.svg.pngExample of a concave polygon (WIKIPEDIA)
Aug 11, 2011 | Computers & Internet
My tv wont turn on
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the center of the caps.
Dec 19, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Af-s nikkor 24-120mm/3.5-5.6g vr disassembly
your efforts are appreciated,must be careful,since disturbing optics result in poor/bad formation of image,if optic surfaces,convex, concave,etcchanges u willnot get image formation as aperture unit is in between the optics,step by step carefully disassemble take out the apartur unit, set the diapharm blades and then assemble.
Mar 06, 2010 | Nikon 80-200mm f/2.8D AFED Lens
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
Jul 02, 2008 | RCA R52WH73 Projection Television
PAPER KEEP JAMING
there were many cases of jamming you might want to check what kind of paper you are using, not all paper are suitable for every machine, make sure there is no obstruction in the paper path nor you material is flat not concave nor convex ( like "u" or "n" in appearance, this will contribute to uneasy access inside you machine
Mar 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Gradients
path problem? cutting problem
Oct 12, 2007 | Adobe Photoshop CS2 for PC
Computers & Internet Logo
590 people viewed this question
Alun Cox
David Payne
David Payne
