Question about Compaq MP1600 Multimedia Projector
Compac MP 1600
I have an MP 1600 and it was working fine then when I turned it bad on all that happens is that the 5 lights on the projector just blink. I have started let sit restarted, Let run for 15 minutes and the lights will not stop blinking. I have even duisconnected the bulb and reconnected it being careful not to touch the bulb. What can I do?
  • 682 Answers
Your prblem will be in motherboard or in power pack module-start to change powerpack module first then motherboard second- or pass it to good sevice center.
Posted on Mar 09, 2008
Won't turn on
How long has it been running, projectors ALWAYS turn off when the overheat remove anything covering the cooling vents and it may have dust inside which will compound the problem.
Solution wait for 5-10 minutes.
Dec 26, 2013 | Epson PowerLite 61P Multimedia Projector
Dell 3200mp lamp
are both of the lamps the same? have you installed it correctly in the socket. you might need to do a cold start for your projector. unlpugg it and try to wait for 5 minutes before plugging it again and turning it on. one your projector detected that a new lamp is intalled, it should work fine now. but if its still not working, you might want to try and replace the new lamp again. sometimes this happens.
hope this helps.
Feb 20, 2008 | Dell 3200MP Multimedia Projector
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | Computers & Internet
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Benq MP 721 projector purple colour when it projects.
You are missing one of your primary colors and this is usually to a faulty pin where you are connecting your vga cable to. It could be either the pin on vga port of your projector or it could be the vga cable itself. Please look at the pins especially if you are using one cable to try with all the compputer.
Jun 02, 2010 | BenQ MP721 DLP Projector
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
DELL 2300 MP NOT TURNING ON
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
Dark Colours pixelate on screen
hey i have the same prob with mine (same model) but it only happens when i send the picture through the rca video in. if i use my pc and use the 15 pin plug, it works fine. i cant explain why it happens, but i jus know it happens.
Aug 11, 2006 | Acer PH110 Multimedia Projector
Compaq MP1600 Multimedia Projector Logo
248 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
