Question about Microsoft Windows 98 for PC
Rebooting of windows98 by itself
I have a p-3 system with 128mb RAM 866MHz clock speed, windows98SE. My problem is my computer reboots all of a sudden by itself like somebody pressed restart button on CPU. Occurs specially when I type something or open control panel or try to check system info. Please help.
  • Anonymous Jan 04, 2008
    I had done windows98 setup in my pc .while driver setup period my pc
    is automatic reboot again & again.please help me .
i am ashish.
simply you change ur ram stick.
Posted on Jan 04, 2008
Hi
i am sam i can said that this i s a problem of motherboard
Posted on Jan 02, 2008
Thanks for the suggestion but I am sure that my problem is purely from software. cause it happens when I usually type something whether a program or simply a letter or may be browsing net. This is not a hardware problem cause if I run scandisk or quickheal virus scan at background it doesn't happen. I have quickheal antivirus latest edition and it found no virus. I checked for any faulty driver in device manager too but all seems to be fine.
very confuused. any other suggestion ?
Posted on Dec 27, 2007
    Genius:
  • 1,601 Answers
First think to check it overheating. Make sure the case is clean inside.Second is a faulty ram stick.The next is a failing processor.
Posted on Dec 25, 2007
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
Computer comes on and is fine for a while then just cuts off,then turn it back on then its fine for a while then cuts back off.
Hello
To start with, you should check all your hardware. A loose connection somewhere or a faulty piece of hardware could be the reason, the computer keeps rebooting itself. In case your RAM stick is not fitted properly, or is corrupt, the computer displays an error message on the screen and keeps rebooting itself. The same problem occurs with a hard disk. You can use 'Memtest86' to run a hard drive check.
You may at times come across an error message on your screen, like a system failure error, before rebooting by itself. There is a particular solution to this type of problem. You should first go to the My Computer icon and right click on it. Select properties, and a window will appear on your screen. Click Advanced tab → Start Up and Recovery → Settings. After clicking the settings option, you will have to uncheck the box next to Automatically Restart. Click OK twice. This will prevent the computer from rebooting itself and you can redress the issue.
A different way to tackle the problem of 'computer keeps rebooting itself', would be to restart your computer in the Safe Mode. Allow the computer to boot fully and let your windows operating system load fully. Now, if your computer keeps rebooting itself even in the safe mode, there is a problem either with the operating system or hardware. And if your computer is not rebooting itself in safe mode, the problem is related to certain software.
Over heating is another reason why your computer keeps rebooting itself. Not many people pay attention to this aspect though. The fan responsible for keeping the CPU cool, may be malfunctioning or there could be dirt settled between the fan and CPU. Any one of these could be the reason for your problem. Either clean the fan area, or replace it if necessary. Try providing proper ventilation for your CPU, so that it stays as cool as possible.
You computer could reboot on it's own if you have installed improper drivers. Right click on the 'My Computer' icon, and click on 'Properties' from the menu list which appears. A new window will open. Select the 'Hardware' tab, and click on 'Device Manager'. A list will be displayed on the screen in which you will have to check all categories. Is you see any red or yellow warning icons, make sure you update that particular driver from the internet.
Dec 13, 2010 | Computers & Internet
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Warning: Your computer CHIP Fan Fail or speed too low.
soem times becasue of heat event system restart. Check your RAM also soem times it could be problem of RAM.
Jun 25, 2009 | ASUS A8N-E Motherboard
I bought 1 GB of Ram ddr 400 for my dell dimension 2400
it might be not compatible.
Do you have the older memory inserted? If yes is it the same speed as the new one you bought?
Is your laptop front side bus capable of a speed of 400 Mhz?
Try to remove the old Ram and use the new one only!
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Computer has 866mhz speed(cpu), 256mb ram but still so slow help
The switches are not something that the average person would need to change. The BIOS can impact the speen but you don't say what you are doing that seems slow. Other things that can cause this are internet speed, lack of ram, too many programs open, antivirus software etc.
Oct 16, 2017 | Dell (1R493) (32 MB) Graphic Card
My Computer stopping
This problem is related to the RAM/Memory of your computer, so if you can upgrade the RAM of your computer that will definitely solve that rebooting problem when installing and playing games...
Hope that helps.........
Aug 26, 2008 | Intel Motherboard
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
CMOS BAD CHECKSUM
Reseat your ram modules and remove the 2nd hdd
try rebooting
If same thing , then reset the Bios to default ,save and exit
Try again..
If same thing ? assuming you have more then 1 stick of ram,, try booting with 1 stick removed . to eliminate ram modules being bad
then switch ram untill you have verified ram chips are or aren't bad
Hope this helps
Nov 13, 2007 | E-Machines eMachines Desktop PC
Microsoft Windows 98 for PC Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
