Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Leaking water from underneath.
This pulled front cover pump ok, hoses ok, leaking water from up under tub? will have to pill the tub and have a look see? hope it's just a seal or something? Squealing..... tub slammed to a stop when opened just before water started leaking from underneath
  • 164 Answers
Sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Posted on Dec 26, 2007
MY front load washer is leaking from under the washer. I have tried doing the monthly cleaning as it states in manual but this has done nothing.
There are several possibilities--the rubber seal between the cabinet doorway and the outer drum may be pulling loose or is punctured in some way. If the cabinet has a removable lower panel on the front, take it off and inspect the pump, the water hose from the drum to the pump, and the drain hose that runs from the pump out the back to the house drain for any possible leaks. If the leak occurs when the tub is filling with water, the hose that runs from the water inlet solenoids to the tub may be split or pulling loose. Open the cabinet top to check this. Hope this helps!
Jan 06, 2011 | GE Washing Machines
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaks while tub is filling.
could be any number of things: water inlet to tub leaking and running down outside tub,tub seal on top of transmission,pump leaking,bad hose washer remove top and front cover,then plug-in and let it start to fill you should be able to see your leak easier that way be careful when plugged-in
Aug 02, 2009 | Amana NAV2335A Top Load Washer
Water leaking
it could be the boot seal, (rubber piece that joins the tub to the front panel). the boot can get a hole in it or it can pull away from the tub if the clamp loosens. if it is the front of the outer tub that is cracked the manufacture did warranty the tub for ten years prior to 2006. check your owners manual as that is what the company has to honor. they only cover the part not labor, and in the usa only. i hope this helps.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water pours out from washer underneath
The most common leak for those washers is from the drain pump a really easy and inexpensive repair. It is located underneath toward the front. To diagnose turn on water to tub fill 1/4 the way, pull out machine about 2 feet, tilt backward,you can use a mirror, I just poke my head under. is should be clearly evident where the leak is. The tools to change the pump it requires a screwdriver and pliers. There are two clips and to hose clamps,remove and replace in reverse order.
Mar 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Dishwasher
Is it not draining or is it overfilling? Overfilling is caused by a float in that little upside down looking cup at the front of the tub. Just remove cover (cup) some are held down by a screw in the back and some just pop off. It's probably just sticking, but you may need a new one if the slide is rusted or the switch burnt out. If it's not draining, then check for anything that fell into the bottom and is covering up the drain grate, and if that's ok, then pull the unit and pull the drain hose off of water pump and under your sink and hit it outside with full pressure water from a water hose, cleaning it out. IF it still has a problem, then you need to replace or rebuild the water pump.
Jan 28, 2008 | Dishwashers
GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 24, 2008 | GE WJSR1070A Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
281 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
