Question about Sony KP-46WT510 46" Rear Projection HDTV
Blurry Curved Picture
My Sony KP-46WT510 tv picture is blurred with red green and blue outlines around everything. I turned it off for a while, then turned it back on again and it went away. Now the problem is back and the picture is slightly curved too. Turning the tv off and on again is no longer working. There seems to be a short or malfunction but where?
  • 2 more comments
  • Anonymous Dec 27, 2007
    I also have the KP-46WT510 46 inch rear projection and mine started doing the very same thing you described. Less than a week ago, it went to the 'blurry screen' with Red/Green/Blue accents, turned it off, waited a bit, turned it back on and it worked for a couple hours and then went 'blurry' again and has stayed that way. Has anyone else experienced this? If so, what is the fix and what was the cost?
  • Tarp Dec 29, 2007
    Sony KP-46WT510 is less than four years old. The picture shows double images. The color red is especially falling in the lower right-hand corner. Sony gave us phone numbers to repair shops that will not travel to us. Estimates between $400-$800, with no guarantee after a year of repair of a proposed convergence problem. I don't want to spend that much more money and have it happen again.
    Sony should be ashamed to place their name on this television. What can I do with the monster?
  • Desertsub Jan 14, 2008
    I have the Sony KP-46WT510 (4-1/2 years old) with the same convergence problem. A nicely curved picture with green and red highlights everywhere. The Flash Focus shows the three colors never converging. I would like to replace the two STK ICs on the D board and think that I have located them as being on the two large heat sinks on the D board at the rear of the TV. Is that correct?
  • Anonymous Jan 20, 2008
    I am having the same problem, curved picture almost looks like a bow tie.
    I've seen comments about heat sink and IC's..what are they are where are they located?
  • 1,694 Answers
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Posted on Dec 26, 2007
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The middle of the picture is fine but the sides of the picture look like they are double with a red outline
The TV has a convergence problem, the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Thanks for choosing FixYA, Big Irish.
Nov 22, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Oct 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
May 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Our picture is green
This is not a user serviceable problem. Apparently the red and blue screen colour tubes/guns are inactive. Possible open green screen control. Also, if CRT type, the tube may be failing
Apr 14, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
202 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
