Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
No display in viewfinder and LCD
The camcorder's viewfinder and LCD are both black when the camcorder is in Tape Mode. And yes, the lens is open. Both the viewfinder and LCD play back video in the Play/Edit mode. I also hit the reset button and that didn't work. Help, please! Thanks! no display in viewfinder or lcd when trying to operate the camera
    Guru:
  • 1,894 Answers
I think you are able too see the video in play back mode. so there is no problem in your LCD.
i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode.
because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
Posted on Dec 25, 2007
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Does not record video
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 02, 2007 | Sony Handycam CCD-TRV608 Camcorder
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
May 07, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
No visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Sep 04, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
239 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
