Question about Cuisinart DGB-600 Coffee Maker
Water is leaking from bottom of base.
I have tried to open the base and have not figured out how. Is there a way to get the Coffee Maker repaired?
  • 6 more comments
  • Anonymous Dec 28, 2007
    hello. when I put water in coffee machine it pour strait thu
  • flo444 Jun 23, 2008
    I've used this machine for a couple of years and now the bottom is leaking.
  • al_froment Jul 17, 2008
    I have the same problem. So far I have been unable to find a solution.
  • marykay1 Jul 27, 2008
    I end of with coffee in the mornings all over my counter and down the floor from where I have set the timer. HELP!!
  • Anonymous Aug 02, 2008
    I have the same problem with wter leaking from the bottom of the base.
  • bgammon Aug 02, 2008
    I have the same problem with water leaking from the base.
  • linadyte Nov 19, 2008
    water is leaking from the bottom of the base. Maybe to say more correctly is pouring, it took couple minutes for all tank to run out.
  • coffeeal Dec 18, 2008
    exact same problem ...water leaking from base
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Posted on May 19, 2008
Water leaking from base of unit: I ran 1/2 cup white vinegar in 1 carafe of water through the coffeemaker. Then repeated. This helped a little with leaking but leaking continued. I called Cuisinart and they said the handle of the carafe has to be centered in the opening after placing the carafe onto the heater base. The handle of the carafe will line up 'dead center' of the word Cuisinart above it on the unit.
We have made several full carafes of coffee, using beans or grounds, with NO leaks! Yay! Maybe this will help.
Posted on Jan 17, 2009
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
My Commercial bunn CWTF-DV-3T coffee maker is leaking water from the top right corner of the machine,and now at the base, behind the burner on the bottom. This happens only when you start to make a pot of...
the fill drain is plugged and the water is overflowing. open the top and, using a phillips head screwdriver, poke through the lime buildup in the trough drain until the water goes down more freely.
Feb 17, 2014 | Bunn NHB Coffee Maker
Dcc 1200 cuisinart coffeemaker leaking water from bottom
Your unit likely has a pin hole in the bottom heating channel like mine. I captured this image of the underside of the coffee maker (with bottom cover removed). I don't know if it's corrosion or just a poorly-manufactured part...or both. It's proudly made in China, so that could be the reason for failure.3_9_2013_6_27_52_pm.jpg
Mar 03, 2013 | Cuisinart DCC-1200 Coffee Maker
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter:
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Delonghi coffe maker leaks water from bottom
The problem is that the heated water is leaking out of the drip chamber. This is caused by the fact that they were to cheap to use stainless steel screws that hold the chamber top to the bottom. The screws have rusted and the hot water can escape the drip area and runs down next to a plastic tube that delivers the hot water to the top of the coffee maker from the heating element. To repair you have to remove two screws that are on the underside of the hot water drip area above the coffee filter. Then there are 3 tabs that have to be released and separate the cover that has the strength control from its base. When you pop off this cover, you will see the remains of 4 screws that are badly rusted. I used a small ez-out and drill to remove the remains. Be very careful to not drill the pilot hole through the top. I got lucky and was able to remove the screws and replaced them with stainless steel. An alternate method would be to use a food grade 100% silicon adhesive and glue the to back together. This method may leak in the future, so try to get the old screws out first.
I would recommend a MR coffee $30 to $50 models, on sale, for coffee before I would ever buy this European designed junk. I took this thing apart and just shook my head and said that you can tell things that aren
Jan 26, 2009 | DeLonghi Caffe Nabucco BCO70...
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Bottom screws
I was just trying to figure this out. I think it's a molded piece because I tried a small hex tool, and everything else. Nothing seems to work...
I HATE trashinh this thing! BOOOOO Cuisinart!!!!!
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Unable to fill water reservoir.
Hi , i thin is under warranty the coffee maker , if try to open by yourself maybe it will lost the warranty , i would like to suggest refer it their technician you may free of damage.
Jan 21, 2008 | Emerson EM83701 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
1,582 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
