take a look on your fuel rail driver side, look to see if there is a test port. If so get yourself a fuel pressure guage and hook er up. fuel pressure should be Min 35 Max 45 PSI if so that rules out fuel pump, Otherwise wait till dark and get a spray bottle full of water, mist your spark plug wires so they are wet and start the truck, if you see little sparks jumping from the wires replace em. last common cause that comes to my mind is check the voltage on your Throttle position sensor black should be ground, purple should be the reading from the sensor and whatever other color should have 5Volts constant aprox. Check your codes too. key on off on off on without starting engine then count the flashes of the check engine light, pauses mean next number... post em and ill let you know what they mean
Remove lead from temp sender on engine and ground lead, watch gauge for kneedle movement if it moves to register then remove and replace temp sender unit, if not check power supply to gauge, and related fuses and or grounds...
ABS LIGHT ON AS WELL?IF SO..I WOULD LOOK AT ABS SENSOR IN REAR DIFFERENTIAL..GETS SPEED SIGNAL FROM THIS SENSOR AS WELL..USES ONE IN TRANS FOR TRANS SHIFTING
This problem is all to common on all dodge trucks in the 90's, the fuel guage sending unit in the gas tank needs to be replaced. They won't sell just the sender, you have to buy the fuel pump module for $300.00
