ASUS A8N-SLI Premium Motherboard
Problem for ASUS A8N-SLI Premium Motherboard
Asus A8N32 SLI Deluxe Motherboard audio problem
By someone7272 on Oct 09, 2009
The board has Realtek's AC'97 chip. This has worked fine for about 5 years, but I recenly rebuilt the PC in a new case (my new one got rennovated with newer components). So I went on to play CoD 5 on this board only to notice the left speaker on the onboard sound is extremely distorted on high volumes. I have to have the volume on max because my speakers aren't amplified. The sound used to be fine. What I also noticed was the LINE IN input left channel is completely DEAD only the right channel for line in works. Also when sound recording, the right channel is OK while the left channel is distorted even worse than through the speakers stream. Is this a running problem with realtek's AC'97 chip or is there more to it? All my drivers are up to date.
Comments:
Oct 10, 2009
- I set it from headphone to 2.1 speaker, but it's still distorted. I'm pretty sure the onboard sound is on its way out because it used to be fine. I might get a PCI Express soundcard but I need one which can handle the front panel connections.
Solution #1
posted on Oct 09, 2009
Somewhat Helpful)
PaulMo
Rank: Wiz  Computer Components  Expert
Rating: 82%, 368 votes
The new boards multiplex the connectors on the back panel to maximize use. Open the Realtek control panel and configure for sterio 2.1. Also, these new boards do not provide any power drive, so to get decent volume, you will need amplified speakers.
Was this helpful?
Yes
No
Popular Solutions for ASUS A8N-SLI Premium
Questions and Unsolved Problems for ASUS A8N-SLI Premium
Do you recommend ASUS A8N-SLI Premium Motherboard?
Answer
Answer
heat trip switch melted
Answer
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla... (More)
Answer
Hi i need a new motherboard model no W340UI and another model number on the same laptop MT3107b
Answer
it not work with my computer i asked for a pin number,can you help me ,sir mad
Answer
asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS A8N-SLI Premium...:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14802
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
