Home | Maytag | Neptune Front Loading Washer w/Built in wat... | Maytage MAH6500AWW Ove...
Maytag Neptune Front Loading Washer w/Built in water heater, MAH6500
Problem for Maytag Neptune Front Loading Washer w/Built in water...
Maytage MAH6500AWW Overloaded washer now leaks when filling
By kris216 on Oct 09, 2009
I put in a comforter which was too large, but I have washed sleeping bags and other large articles before with no problem, so I closed the door until the door locked. That load finished without further incident. The following small load had no incident, but the small load after that started leaking out the bottom of the washer while filling. I quickly turned the machine off and then ran a spin cycle to eject any water. The leaking stopped during the the 7 minute spin. I tried to start up a wash cycle, but it started leaking during filling, again. For the second time, I stopped the wash/fill cycle, and ran another 7 minute spin. The leaking stopped and here I am on the computer trying to find out what to do so my husband doesn't have to trouble-shoot when he gets home.
Comments:
Oct 10, 2009
- Found the problem. The grey rubber seal between the door and tub is torn from when I overloaded it with the comforter. Leaks all over the floor right from the center tear at bottom of seal. (Also torn near the top. I will never overload again!!) Need to order a new seal. Any help with where to order one online??
Solution #1
posted on Oct 09, 2009
Not Rated)
milten1
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 90%, 473 votes
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Comments:
Oct 11, 2009
- call appliance parts pro
1-877-477-7278
order the following part number
AP4010226 boot seal 51.13
ill talk you through it when it arrives
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune Front Loading
Questions and Unsolved Problems for Maytag Neptune Front Loading
Do you recommend Maytag Neptune Front Loading Washer w/Built in water heater, MAH6500?
Answer
Answer
2002 Maytag Neptune front load washer has an odor like a burnt rubber odor.
Answer
the door on our maytag front load washer will not lock / close all the wall.
Answer
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it.... (More)
Answer
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control... (More)
Answer
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune Front Loading...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
