Question about Nintendo DS Console
Nintendo DS charger plug is stuck
My daughter just opened up her new DS and my son (a seasoned veteran at the game) helped her set it up. He plugged in the charger, and when he went to unplug it, the plug would not come out. I looked at it and can see that it seems that the plug is stuck in such a way that it is articulating on something. The charger is from a pelican play pack. Any suggestions?
  • 15 more comments
  • Anonymous Jan 21, 2008
    Yup got the same problem. Bought one for my father which arrived today. He plugs it in to charge it and then can't get the adapter out. Seems to have locked itself in somehow. Any suggestions greatly appreciated.
  • brille Jan 27, 2008
    same thing happened to me with the dstt usb charger.
  • Anonymous Jan 31, 2008
    same :(
  • Anonymous Jun 08, 2008
    I also have the same problem ! I bought a DS lite charger from Game UK and it is stuck in my console. I'm really annoyed at this.
  • tags1 Jun 28, 2008
    Have the exactly same problem. Very frustrating. Seems like it is a known fact. Why is it not being checked before they ships these productsIin my case I got it yesterday from Amazon).
  • Anonymous Aug 05, 2008
    yep brand new from argos !!! wiggled side to side to get it out. CHEERS.
  • Anonymous Aug 19, 2008
    Yep mine was brand new from Argos too. So far am still working in it with no success, still stuck!
  • davebowden39 Aug 25, 2008
    Hi, have just bought my son one from argos for his birthday (6th) and the same thing has happened, any advice?
  • Anonymous Oct 23, 2008
    Nintendo DS lite - Same issue - must be a child protection which does not work properly.
  • chrisdpops Nov 18, 2008
    same problem here, got mine from ebay, brand new from the box.....Aggghhh!!!!!!!!!!!1
  • Anonymous Dec 25, 2008
    I bought the ds same problem and still stuck will not move
    yes, same problem just opened gift this morning..using all forces and all idea possible except for dissemble and nothing is working. has anyone had a successful release of charger
  • Anonymous Dec 26, 2008
    aaaargh! same same - can't get it out - have tried everything - so it will be going back to the store with a print out of all these logged probs as evidence of a product fault!
  • MeganeChick Dec 29, 2008
    yes this has happened to me too - just plugged it in for the first time and came to take it out when it had charged and it is stuck firm - no amount of force will get it out.
    going to take it back to the shop as it seems a few people have said there is a fault with this
  • Anonymous Dec 31, 2008
    hi, i have the very same problem and im taking my console back to game.
    the charger is stuck solid in the console?
    joe
  • bandon18 Jan 08, 2009
    Hi, yes have the same problem. Plugged in the charger on Christmas day and it is stuck fast!. The console works fine but i can' remove the charger. I thought that maybe i had inserted it incorrectly but no. This was a gift from Santa for my 7 year old son and even though he doesn't mind, until i saw other people with the same problem, i wasn't aware that it was a fault with the console. Has anyone had a problem with the shop you returned it to? I got it in Exravision so I hope the will replace it for me. Can anyone let me know? I am in Ireland. Thanks
  • MeganeChick May 11, 2010
    after you managed to free it then what happened if you tried to charge it again? did the problem repeat itself?
    Problem Solver:
  • 9 Answers
If you can fit anything in between the charger and the socket like a piece of very thin laminate etc you may be able to free that lodged pin, make sure if you do try this you use something non conductive and you also remove the battery first.
Posted on Jun 17, 2008
Hi, Just read your answer and me too! Tried the 'side to side wiggle' and it worked!!!! Thank you so much - it really was great to see that i wasn't the only one with the problem and that to read other solutions tha work - Thanks Again
Posted on Jan 08, 2009
    Try the side to side wiggle . Read it here and rid it with my console and it really works!!!
We had same problem and went for 3 days trying to sort this out.  we read this forum and the "side to side wiggle" did the trick.  THANK YOU.  now it does in and out just fine.  it only had a problem on the first plug-in.
Posted on Jan 02, 2009
Mine was from Argos but I think it may be a problem with the DS. A side to side wiggle with a fair bit of pull sorted it for me.
Posted on Sep 29, 2008
Unfortunatly I had the same problem. I found that if you pull at it with a little bit of force, at an angle it comes out. If that does not work jiggle it for a sec or two and try again. GOOD LUCK!!!!!!!
Posted on Jul 10, 2008
I actually ran across that same problem yesterday and no amount of "wigginling" helped. So I used this guide http://gbatemp.net/index.php?showtopic=98240 to open it up and fix the little piece that had gotten the charger stuck in the first place. So I'd recommend doing that if you don't mind opening it. You will need a triwing srewdriver which is rare to find, I had to buy one from an electronic hardware store for 7 dollars, but it worked. So good luck to anybody else that runs into this problem.
Posted on Mar 30, 2010
I just had the same problem with Nintendo DS bought in US used with SpeedLink accessory power adapter for 220 V. Side-to-side wiggle + slight lift angle to the upper side and quite some pull force got it out. However, native 110V plug works okay. There seems to be a slight dent on SpeedLink one, not sure if it was a result of this pull, but thanks everyone for suggestions!
Posted on Jan 09, 2009
I took mine back to the shop i bought it from as it was still within my 28 days and they replaced it. the person behind the counter gave it a huge tug whilst keeping grip of the charger plus by wrapping the cable around his hands (which i certainly didnt want to do) it came free.
inspection of the plug showed that it was slightly misshaped and we didnt try it again. my new one is absolutely fine - so i would advise getting it replaced as you dont know what problems this could cause down the line.
Where would you recommend I send it into? Back to Nintendo?
Posted on Jun 06, 2008
I got mine out, had to disassemble the ds.
The problem was a pin on the upper side of the ds inside the charger opening. The pin locked in a hole in the plug from the charger.
So if you dont want to disassemble your ds you'll probarbly have to send it in.
Posted on Jan 31, 2008
Same :(
My son has a DS lite. It was working fine and now
possibly fuses have blown on the logic board, but it sounds like it needs a new one board.
Jan 07, 2010 | Nintendo DS Lite
Car chargers stuck in nintendos, 2 upset daughters
did u try plugging them back in to the car ,maybe they heated up if so plug them in leave them for as long as when it happened and then try with a pliers for extra grip(twisting), a bad idea would be to splice the wires with the wall chargers by cutting of the ends and joining them that way but you would need to now what you are doing
Feb 25, 2009 | Nintendo DS Lite Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
DS won't charge!
Bluesbelle,
Are we talking here about a DS or a DS Lite?
Jul 24, 2008 | Nintendo DS Lite Console
Nintendo DS Lite will not charge
GET A NEW CHARGER HAPPENED TO ME BEFORE my bad caps lol
Jul 18, 2008 | Nintendo DS Lite Console
Need to know how to what's wrong & how to fix
for ur sons DS try to move it around to find a signal. for ur daughter's, trying doing the same first and if it doesnt work, buy a new charger if the new one doesnt work its the DS
Nov 02, 2007 | Nintendo DS Lite Console
DS charger
get a new battrey or google it ,go to nintendo.com , or u might have to get a new one
Oct 16, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
1,428 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
