Hannspree 28" Widescreen Flat-Panel LCD HD Monitor
Problem for Hannspree 28" Widescreen Flat-Panel LCD HD Monitor
Hi.. i have a 28"
By winseeker on Oct 09, 2009
hi.. i have a 28" monitor which has been working fine. just started this issue. It is being used with a notebook comuter as a second monitor. when turned on the monitor shows the screen for about 40 seconds and then goes to black. I cant get it to kee the image in lace. always going to black after about 40 secs.
Solution #1
posted on Oct 09, 2009
Not Rated)
rulds2008
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 1171 votes
I feel this is a resolution problem that your laptop wants to display a higher resolution then the monitor can handle or you got a issue with the logic board inside things to try is hooking it up to a different system if that works you need to rule out why the laptop is all of the sudden trowing this into a loop my best advice would be look into the laptops settings maybe those got changed by accident?
So check these things out first.:
  1. laptop video settings set it for a lower setting like 800X600 if it stays lit you know you had the wrong setting if it does not stay lit you do indeed have a logic board problem inside the monitor.
  2. Check this with another computers video card just maybe you laptop is failing to handshake with this monitor that happens when a laptop is showing signs that its video card is going out.
  3. if you monitor does not work ether on a pc or your laptop with the new settings you got your answer you can buy a new logic board for under $50 bucks and have it put in.
You like my advice? Please click the ACCEPT BUTTON. if you have question please reply to expert.
Thanks and best regards
Rulds2008
Expert Moderator
Popular Solutions for Hannspree 28" Widescreen
Questions and Unsolved Problems for Hannspree 28" Widescreen
Do you recommend Hannspree 28" Widescreen Flat-Panel LCD HD Monitor?
Answer
Answer
got a new 28" lcd hdtv and picked up a scientific atlantic set top, can not set up tv get only... (More)
Answer
i have sound but no picture on my hannspree lcd tv. Can't even see the menu screen
Answer
not able to get nbc network .have old tv working on same antenna with converter box and i can get it... (More)
Answer
hannspree ST281MAB. Need code to work my sky HD,TV controller
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
