Question about Sony PS-LX250H Turntable
Trouble getting new turntable to work
Got a new turntable for christmas but unable to get turntable to go around-
have tried to loosen screws on botton-this was a floor model so no instructions were provided-any suggestions would be appreciated
Make sure the belt is installed correctly, you can go to sony.com and get the assembly manual right there
Posted on Jun 12, 2008
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I have a Crosley Authentic Reproduction phonograph/am/fm player. The turntable won't turn. I have loosened the screws used for transporting. The belt was not connected but the white spindle to the
    First see if you can manually turn the shaft by hand. If it freely turns then it will be a power issue. If it doesn't the motor might have seized up. Some oil should correct it.
    If it's a power issue you should look around for bent or broken switches.
    If the motor to the deck operates under 12 volts. You can connect a 9 volt battery to it. If that doesn't turn it the motor is faulty.
    Apr 28, 2014 | Crosley (CR47) Turntable
    Troubles Sony ps-b80 1)When power sw is on,red
    try getting itr cleaned by a reputable repair shop may just b dirty
    Oct 02, 2013 | Audio Players & Recorders
    I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
    Shipping screws are used the hold down the turntable during shipping.
    These shipping screws need to be removed after shipping and installation.
    Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
    Unable to unscrew philipshead screws on circular magnet around the bearing to isolate the bearing. It appears that philipshead screwdriver does not fit as there is a lot of play between screw and...
    There are all sorts of screwdriver bits you can get that will slacken the screws. If you don't get the right one it won't turn. To be honest I would look at a new motor, unless you already have a found it to be expensive.
    Dec 02, 2010 | Panasonic Technics SL-1210MK2 Turntable
    New Memorex 9285MMO, loud hissing + ring dig on record
    Probably the needle, I work on them and many needles are bad from new. They were put on wrong in the first place. Try taking the red part off and make sure there is a needle part and that its straight.
    Jan 16, 2010 | Memorex MX212 Turntable
    How to connect an Aiwa LX70 turntable to an Aiwa NSX-AV95 stereo system . The red and the white are fine where does the cable with the plug fit and where does the loose end wire fit ( i thought it was...
    there should be a small round connector on the rear of the turntable for the mains transformer supply and the loose wire is the earth/ground connector which should be connected to the screw connection on the rear of your amplifier? just loosen the screw ( usually brass or steel ) on the back of the amp, wrap the thin earth wire around the thread making sure it has some exposed copper ie, strip a bit of the cable and then tighten it back up? good luck
    Oct 03, 2009 | Aiwa Audio Players & Recorders
    Need free owner's manual for a Detrola record player Model KM837
    unable to follow what is wrong.
    are you talking about the tonearm or a lever at the power switch?
    Jan 25, 2009 | Crosley CR248 Turntable
    Tone Arm
    (remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
    Aug 12, 2008 | Technics SL-1200MK2 Turntable
    JVC turntable LA10
    The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
    Hope that helps.
    Mar 16, 2008 | Audio Players & Recorders
    Sony PS-LX250H Turntable Logo
    102 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
